Post by tsimi on Apr 26, 2017 17:00:24 GMT -5
...red Jog for starters. Later maybe on the prebug using a subframe.
Post by tsimi on Apr 27, 2017 7:39:30 GMT -5
Post by benji on Apr 27, 2017 9:53:47 GMT -5
Yup, having no luck finding one out here. You may be able to just replace the inner cable portion? Or just wing it like me haha.
Post by tsimi on Apr 27, 2017 10:03:16 GMT -5
benjiNo worries I placed an order for a new one already.
Post by ryan_ott on Apr 27, 2017 10:03:46 GMT -5
Post by tsimi on Apr 27, 2017 10:11:28 GMT -5
ryan_ottYep that seems to be the right one. I already placed an order with scooter-center[dot]com I also needed the key lock unit and a few other things and they had everything in stock. The only thing I am still missing is a center stand but I ordered a side stand which should do until I can order one.
Post by ryan_ott on Apr 27, 2017 10:20:35 GMT -5
Looks like the stand is still available but expensive, maybe see if something from your scoot junkyard could be made to work.
Post by benji on Apr 27, 2017 12:38:02 GMT -5
If you got a side stand coming, your good. The center stand is nice for working on it tho, but it's heavy! I have one but some one cut one of the legs off for some reason, making it useless.
Post by tsimi on Apr 27, 2017 20:42:13 GMT -5
I need a center stand otherwise tire changes and work in general gonna become a pain in the ass.
Post by PIG on Apr 27, 2017 21:20:12 GMT -5
I need a center stand otherwise tire changes and work in general gonna become a pain in the ass. That's exactly why I keep my centre stands. I just slap it on without the springs, do what I gotta do then pull it off.
Post by tsimi on Apr 27, 2017 22:52:39 GMT -5
PIGThat's smart. I shall do the same.
Post by tsimi on Apr 30, 2017 5:53:12 GMT -5
So on April 25 I placed an order at maxiscoot for the front and inner panel. Today April 30 they arrived. That was very fast. On top of that the panels were very well packed and arrived undamaged. Not even a tiny scratch.
Post by tsimi on Apr 30, 2017 7:23:28 GMT -5
I almost got everything sorted out and I am soon ready to take her out for regular driving. The last thing that I need to get fixed are the turn indicators. When I lightly tab on the flasher relay the turn signal becomes faster as it should be. More faster I tab on it more faster the turn light interval becomes. I guess the flasher relay is shot? Now I need to find replacement and there is where I am stuck at the moment. I need this kind of relay. I can barely see what's written on the relay. Omron G8MF- / 12.8V 8Wx2 Does anyone know where to get one?
Post by PIG on Apr 30, 2017 8:19:44 GMT -5
Post by 90GTVert on Apr 30, 2017 8:46:43 GMT -5
I'd try a generic flasher relay from a local parts store (prob $5 in the US) before I spent $40 on the Yamaha piece. You could make up quick jumper wires to make sure it works before you do any permanent modding of the wiring since they're just 1/4" quick disconnect terminals in most cases. If it works, then it's cheap and easy if you ever have to replace it again. If not, maybe you could return the flasher so you aren't really out anything but a little time. I'm a cheapskate accustomed to Chinese scoots though, so maybe I'm discounting plug and play value for some. If you do go with a generic unit, consider a 3 wire (adds a ground) if you want to use LED signals. You'd have to run a ground wire (frame is fine), but those are the only ones that never give me any issues with LEDs.
