Post by benji on May 6, 2017 10:08:06 GMT -5
I don't think so... but the battery is so small on these scoots in general that any big draw might hurt the system. I turned my hi-lo switch into a on/off switch (hi-beam on, lo-beam off) so I can keep the draw down of i need it.
Post by PIG on May 6, 2017 12:19:40 GMT -5
I don't think so... but the battery is so small on these scoots in general that any big draw might hurt the system. I turned my hi-lo switch into a on/off switch (hi-beam on, lo-beam off) so I can keep the draw down of i need it. Mines set up the same way
Post by tsimi on May 6, 2017 18:30:11 GMT -5
How can I do that? That On/Off thing?
Post by benji on May 6, 2017 18:45:32 GMT -5
Yup. Just hook both headlight wires(hi-beam and lo-beam) on each bulb up to the hi-beam wire in its socket.
Post by tsimi on May 6, 2017 19:11:21 GMT -5
Yup. Just hook both headlight wires(hi-beam and lo-beam) on each bulb up to the hi-beam wire in its socket. That's it? That sounds easy enough and even a noob like me should be able to do that. Thanks.
Post by tsimi on May 7, 2017 1:00:21 GMT -5
I couldn't leave it and did the full bulb and relay swap. Replaced all flasher bulbs to 10W and installed the 10W relay that I got the other day and voila! May there be light, well flashing lights to be exact. Now everything works as it should. So I guess it was the 8W flasher relay after all. Also replaced one of the headlight bulbs (12V15/15W) and now headlights work as they should. Both lights shine btw. for normal and high beam. I am glad this is over. Now I can drive her in good conscience.
Post by PIG on May 7, 2017 10:33:13 GMT -5
Now swap in a MXS Race. They're unreal in a prebug, you'll love it.
Post by birdman on May 7, 2017 12:23:40 GMT -5
Nice prebug tsimi!! That's an awesome score.
Post by tsimi on May 8, 2017 18:18:56 GMT -5
Took her to work today and she drives very nice and smooth. I hit 60km/h (37mph), GPS confirmed, before I ran out of road.
She smokes like crazy especially at WOT. I guess too much oil gets pumped in there?
I definitely need a higher and stiffer rear shock.
All in all the Prebug is a nice 2T to ride. Maybe one day I might follow in PIGs footsteps and install one or the other performance parts. But for now this is my rain bike and I need to keep her in stock condition.
Post by spaz12 on May 8, 2017 19:59:33 GMT -5
Took her to work today and she drives very nice and smooth. I hit 60km/h (37mph), GPS confirmed, before I ran out of road. She smokes like crazy especially at WOT. I guess too much oil gets pumped in there? I definitely need a higher and stiffer rear shock. All in all the Prebug is a nice 2T to ride. Maybe one day I might follow in PIGs footsteps and install one or the other performance parts. But for now this is my rain bike and I need to keep her in stock condition. Pull the pipe and use a heat gun on it or a torch. It probably has a bunch of oil in it from sitting.
Post by tsimi on May 8, 2017 21:04:16 GMT -5
Yeah most likely. Doesn't it get better once I drive her for a while? I have a heat gun, what should I do with it exactly?
Post by benji on May 8, 2017 21:05:34 GMT -5
Take off the muffler and get it crazy hot to burn off all the extra stuff in it. I guess an old barbecue works too, haven't tried it tho.
Post by spaz12 on May 8, 2017 21:07:50 GMT -5
Yeah most likely. Doesn't it get better once I drive her for a while? I have a heat gun, what should I do with it exactly? I supposed it would eventually clear itself, assuming that the large smoke trail doesn't bother you that much. Otherwise, pull it off, place it on your driveway with the heat gun pointed at it and walk away. Come back when she stops smokin
Post by tsimi on May 8, 2017 21:21:25 GMT -5
lol 2T smoke never bothered me.
Post by tsimi on Jun 10, 2017 19:25:06 GMT -5
