Post by map on Apr 25, 2017 21:03:02 GMT -5
So I took everything off almost from the engine, didn't expect to be stuck by the flywheel. So I need a puller but I don't know what's a cheap one and what size I need. How can I find out? I used a 14mm socket to take off the nut holding it in place if that helps.
Post by FrankenMech on Apr 25, 2017 23:21:21 GMT -5
The scoot part supply places have the special tool for pulling the flywheel. It is engine specific.
Post by map on Apr 25, 2017 23:41:02 GMT -5
The scoot part supply places have the special tool for pulling the flywheel. It is engine specific. How can I check which one I need based off my engine?
Post by FrankenMech on Apr 26, 2017 0:40:22 GMT -5
Call and they will ask questions to help you identify what you need.
Post by map on Apr 26, 2017 0:55:05 GMT -5
Call and they will ask questions to help you identify what you need. I could be tired or I must not have read it right, but call who exactly?
Post by 2stroked on Apr 26, 2017 9:56:00 GMT -5
Partsforscooters.com
List flywheel pullers by engine type.
Post by map on Apr 26, 2017 11:35:05 GMT -5
Post by 2stroked on Apr 26, 2017 11:59:33 GMT -5
PFS part number 202-7
Pit Posse cross shape 139qmb flywheel puller
Post by 2stroked on Apr 26, 2017 12:01:12 GMT -5
Idk why I can't post links. Havenbbeen able to for days now. But, O found that one in a quick search, just get the specs from it an dmatch those specs to a cheaper puller
Post by pinkscoot on Apr 26, 2017 12:03:06 GMT -5
I've used a steering wheel puller before. You need to get some long bolts that fit your flywheel and some heavy washers but it does the trick. The scooter flywheel puller is an easier way to go.
Post by pinkflames420 on Apr 26, 2017 13:58:45 GMT -5
Okay so sorry, what scooter are you looking to use the puller on? It IS a qmb139 correct?
Post by map on Apr 26, 2017 15:19:52 GMT -5
Yes, it's a QMB139 Engine. The scooter is a 2008 Roketa. 50cc
Post by pinkflames420 on Apr 26, 2017 17:28:19 GMT -5
Just checking... That's the one 2stroked posted earlier ^^ from PFS. www.partsforscooters.com/202-7-Fly-Wheel-Puller""" The following sizes can be used: M10x1.25R M14x1.5R M16x1.5R M18x1.5R M24x1.0R M27x1.0L """ This should work? It says it's for GY6 aswell, so I assume it's a little universal.
Post by pinkflames420 on Apr 26, 2017 17:31:02 GMT -5
Sorry it's not reeaaalllyy universal, it has different sides to it. 6 of them too choose. What I silly comment
Post by FrankenMech on Apr 27, 2017 1:55:39 GMT -5
Call and they will ask questions to help you identify what you need. I could be tired or I must not have read it right, but call who exactly? Read the previous posts.
