Post by ryan_ott on Jun 24, 2017 14:15:53 GMT -5
They do sound good but when driving they are quite annoying.
Post by spaz12 on Jun 24, 2017 14:45:53 GMT -5
Is that a Malossi adjustable CDI that I see?
Post by ryan_ott on Jun 24, 2017 14:58:46 GMT -5
It's actually top performance, I have one of the malossi ones and they give about 4-5 deg of retard. I'll graph this one and see what it gives.
Post by ryan_ott on Jun 25, 2017 16:27:34 GMT -5
Has anyone else found malossi straight cut gears to be noisy! I'm using 75/90 Mobil1. I can hear them over my pipe. I've changed the fluid and nothing abnormal was in there. I guess just the straight cut...
Post by PIG on Jun 25, 2017 17:36:40 GMT -5
Post by tsimi on Jun 25, 2017 18:19:39 GMT -5
ryan_ottI have zero experience with gears but I have read many times that the Malossi gears are louder then stock, kinda sound like a turbo they said. Not sure how a turbo sounds though. But if you say you can hear them over your pipe then they must be really noisy. You got a video of it?
Post by spaz12 on Jun 25, 2017 18:26:17 GMT -5
I've read that they are loud, but I don't hear them myself. Maybe because my pipe and open filter? Silly to ask you, but did you get the spacing correct when you pressed the gears?
Post by 190mech on Jun 25, 2017 18:49:40 GMT -5
Post by moofus02 on Jun 25, 2017 19:13:37 GMT -5
Post by ryan_ott on Jun 25, 2017 19:16:02 GMT -5
I've read that they are loud, but I don't hear them myself. Maybe because my pipe and open filter? Silly to ask you, but did you get the spacing correct when you pressed the gears? I'd did I used feeler gauges and it's dead on.
Post by moofus02 on Jun 25, 2017 19:16:28 GMT -5
Post by ryan_ott on Jun 25, 2017 19:17:47 GMT -5
ryan_ottI have zero experience with gears but I have read many times that the Malossi gears are louder then stock, kinda sound like a turbo they said. Not sure how a turbo sounds though. But if you say you can hear them over your pipe then they must be really noisy. You got a video of it? I'll try to capture it on video tomorrow. It's not ear piercing loud but it's noticeable louder then stock.
Post by ryan_ott on Jun 25, 2017 19:23:42 GMT -5
Is that the same stuff that was in the older "break in" oil?
Post by SandStorm on Jun 25, 2017 19:41:50 GMT -5
Don't worry. It's normal straight cut gears to be noisy. This is pretty common in car racing when they use those gears.
Post by joshua864 on Jun 25, 2017 20:28:38 GMT -5
Straight cut gears are always noisy but its normal
