Post by shiftless on Nov 13, 2009 23:13:58 GMT -5
I recently got ahold of a 06 E-Ton Beamer It was a police impound that my bud turned me on to Looked like this when I brought it in Iv'e got her stripped down to the frame & the engine on the bench right now and going through everything This weekend I'll put it back together and see if she fires Planning a 70cc sport, and am deciding between a couple pipe options I'll keep u up 2 date on the progress
Post by 90GTVert on Nov 14, 2009 3:18:05 GMT -5
A little rough around the edges, but definitely has potential. Good luck with it.
Post by shiftless on Nov 14, 2009 11:47:32 GMT -5
Thanx It does have potential It is rough 4 sure, but has lo miles and the engine seems to be in great shape, with the exeption of a crack on the right front case I'm waiting for a puller & sum gaskets I ordered to replace it I have the part thanks to 2strokd It was missing a couple of plastic pieces, which I found and ordered from anythingatv.com Meanwhile, I'm cleaning it up and waiting on my stuff I've been wanting a lil 2t for a while ;D
Post by 2strokd on Nov 16, 2009 10:26:39 GMT -5
Itle polish up just fine
Post by shiftless on Nov 16, 2009 11:21:18 GMT -5
Itle polish up just fine Yup I cleaned the plastic up good Used some of this stuff Let dry to a haze Buffed it up good, a lot of minor scratches went away Had to use a lil epoxy on some cracks Came out much better than it was Degreased the the lower pieces (they were filthy) Cleaned up the frame and went through the harness Waitin on some tools I ordered to fix the cracked case I should have her all together in a week O yea... I traded a set of forks for a mrp pipe ;D
Post by 90GTVert on Nov 16, 2009 20:23:06 GMT -5
Everyone seems to like that Kit scratch remover, I've never had any luck with it. Oh well, the important part is that it worked for you.
Have you got any particular sport kit in mind for that MRP pipe to bolt to?
Post by shiftless on Nov 17, 2009 2:03:47 GMT -5
Pretty much got my mind set on a Polini 70cc Sport I got the pipe for some junk I had, I was gonna go with a Tecnigas Trek, but I'll try the MRP since it was pretty much free Put it 2gether tonite....... engine work is next Waitin on a part or 2 Gotta replace a crakd right side case I hope to get the engine in it soon
Post by 2strokd on Nov 17, 2009 8:45:14 GMT -5
Looks loads better than it did the other day The Beamer front plastic looks home to a nice big radiator to cool a L/C Aerox 100cc Minarelli? No? Well i thought so Ya got your cylinder yet?
Post by shiftless on Nov 17, 2009 10:44:03 GMT -5
Post by 2strokd on Nov 17, 2009 11:48:59 GMT -5
From what everyone says autotech sells a great kit. Good buy! Probably not quite as much torque as the Polini Sport but according to the port map it should make some steam if tuned good. I dont think you can beat it for the money . If you have ever dealt with auto you know that he is very fast to ship and has great customer communications ;D. Edit: Noticed thats a 10mm pin set-up. Isnt yours a 12mm?
Post by shiftless on Nov 17, 2009 13:12:14 GMT -5
Mine's a 10mm I've been dealing with Carlos for a long time I figure since the engine is imn teardown mode and the case is coming apart .... I might as well do the cylinder too I can afford this 1 friday Putting it 2gether stock aint gonna make me happy anyway ;D
Post by 90GTVert on Nov 17, 2009 15:23:04 GMT -5
The Beamer front plastic looks home to a nice big radiator to cool a L/C Aerox 100cc Minarelli? No? Well i thought so I thought the same thing when I looked at that front pic. ;D
Post by shiftless on Nov 17, 2009 21:50:05 GMT -5
Well thats what some1 told me, but I pulled the top end before ordering a kit, and found different 15mm pin Sorry but I'm still bustin my 2t cherry The bore WTF
Post by 90GTVert on Nov 17, 2009 22:21:54 GMT -5
You sure your mics aren't about 5mm off? lol Never seen a 15mm pin. The bore is about 5mm too big too. Does the engine say "1E40QMB" or something like that on the case?
Post by shiftless on Nov 17, 2009 22:46:59 GMT -5
Yup thats xactly what the deal was, Put a new battery & zeroed caliper and its all good (HF tools : I just thought wtf do these minni's vary that much Like I said ... I'm just bustin my cherry with these engines Back on track, DUH ;D, Thanx Brent.... I was trippin 4 a sec
