Post by Delpzie on Jul 14, 2017 19:44:41 GMT -5
Baotian Falcon 50R (BT49QT-28C) Here is my Baotian Falcon 50R swapped with minarelli LC engine from Yamaha Aerox as now it has: -Stage6 SportPRO MK1 70cc cylinder kit (also known as Athena Sport 70cc) -Stock chinese crank (cpi/keeway/baotian etc..) -Yasuni C21 Kevlar (just bought 1week ago) -Polini Hi-Speed Vario -Malossi MHR Ventilar -Dellorto Stage6 Black Edition 21mm carb -Polini E5 Airbox -Polini Speed Belt -Stage6 SportPro Clutch -Malossi clutch bell 107mm -Minarelli cdi (the stock cdi died from too much rpm ) Very soon i will be replacing the crankshaft with RMS Super Racing crank, Malossi Selletra innerrotor ignition, Reed Valve Stage6 V-Force3 by Tassinari, Overrange malossi vario + morini 128mm pulley (from di-tech aprilia) and porting the stage6 cylinder and the engine blocks. One older picture when it had the Polini Scooter Team2 Exhaust Video with the C21 exhaust, there are other videos too on my channel from the scooter. www.youtube.com/watch?v=DOAaXd35T_E
Baotian
Jul 14, 2017 21:32:29 GMT -5
via mobile
Post by greggkinney on Jul 14, 2017 21:32:29 GMT -5
welcome!!! sweet looking scoot, sounds like a nice list of mods too
Post by joeorange on Jul 17, 2017 22:11:19 GMT -5
that almost looks like the early model aprilia SR50.
Baotian
Jul 18, 2017 0:32:12 GMT -5
Post by spaz12 on Jul 18, 2017 0:32:12 GMT -5
Damn good looking scoot!
Baotian
Jul 18, 2017 8:27:46 GMT -5
Post by joeorange on Jul 18, 2017 8:27:46 GMT -5
also i dont know if its just me, but the crank looks almost exactly like my Naraku HPC crank. but mine has the 16mm 15 splined shaft. im guessing his has the 13mm 17 spline.
Baotian
Jul 18, 2017 12:23:28 GMT -5
Post by Delpzie on Jul 18, 2017 12:23:28 GMT -5
Yea mine is 13mm for the minarelli engine , now i have stock 16mm i mean they are pretty much the same cranks just diffrent packaging.
Baotian
Jul 18, 2017 12:35:18 GMT -5
via mobile
spaz12 likes this
Post by ryan_ott on Jul 18, 2017 12:35:18 GMT -5
Good looking scoot you have there. Rear disc... nice! Do yourself a favor and get a starter block off plate to cover where the starter was. A rock could cause some serious carnage in there.
Baotian
Jul 18, 2017 13:14:36 GMT -5
Post by Delpzie on Jul 18, 2017 13:14:36 GMT -5
Actually never thinked of that, thank you for pointing out Ryan will do that these days.
Baotian
Jul 26, 2017 7:57:13 GMT -5
Post by Delpzie on Jul 26, 2017 7:57:13 GMT -5
Got new oil today, will start disassembling the scooter in 2 or 3 days.
Baotian
Jul 26, 2017 10:46:01 GMT -5
Post by Senna1Rossi on Jul 26, 2017 10:46:01 GMT -5
Noice!
Post by Delpzie on Jul 28, 2017 18:33:50 GMT -5
On my way to VlatX something happend the scooter was runing fine i was crusing with like 80-90km/h not forcing it, then speed started dropping to 60km/h and the rpms too but it was still pulling, after that i stopped i needed to wait for my friend then i try to start it up the kickstarter just goes so easy like there isnt compression , tomorrow we will disassemble to see what happend but i think the chinese bearings just died from much rpm who knows, also i might buy RHQ crankshaft and buy piston for the MHR Team 6T cylinder kit which i have and put that, i will try to sell the rms crank to get some money back.
Post by Delpzie on Jul 29, 2017 13:12:25 GMT -5
Post by Delpzie on Aug 15, 2017 12:06:10 GMT -5
Raised the exhaust port to 20mm, no tools to acess the other ports and raise the exhaust port even more, thats it for now for this cylinder, the old piston was 47,44mm and the cyilnder is 47,61mm so i ordered new piston, piston ring in reserve and gasket set waiting to arrive , the crank is assembled and the engine blocks ported.
Post by Delpzie on Aug 17, 2017 18:57:22 GMT -5
Baotian
Aug 18, 2017 14:10:57 GMT -5
Post by Delpzie on Aug 18, 2017 14:10:57 GMT -5
All ready but the pulley fcked me so hard , i gave almost 50euros for it so it would fit and still it didnt fit,its too long, im so done with this.
