Post by Delpzie on Mar 29, 2018 13:38:20 GMT -5
I plan this map actually raised exhaust 19,8mm and widen 1,5mm, the port analyzer says 30,6hp which is just what i wanted .
Post by benji on Mar 29, 2018 20:12:15 GMT -5
"port analyzer"? Please elaborate!
Baotian
Mar 29, 2018 23:40:26 GMT -5
Post by spaz12 on Mar 29, 2018 23:40:26 GMT -5
Here is the new carb, it came with 120 main 48 pilot jet , i bought sets for fine tuning , the needle has JJY mark on it. Still dont know how to port this cylinder if someone can suggest i will be thankfull , i plan to port it kinda like this what do you think? That's an aluminum and nickasil cylinder? Not impossible, but very difficult and more than likely you'll chip it and need to replate it.
Post by Delpzie on Mar 30, 2018 8:53:51 GMT -5
Here is the new carb, it came with 120 main 48 pilot jet , i bought sets for fine tuning , the needle has JJY mark on it. Still dont know how to port this cylinder if someone can suggest i will be thankfull , i plan to port it kinda like this what do you think? That's an aluminum and nickasil cylinder? Not impossible, but very difficult and more than likely you'll chip it and need to replate it. Not this map , we will port only the exhaust and the analyzer says 30.6hp @14k but the psi is above 200 so it might not work as well will be hard to tune , im making other maps to see whats the best and still make 21-22hp on the wheel, btw porting wont be problem my friend VlatX will port it we already ported the previous nicksail cylinder sport pro so he is not newbie.
Baotian
Apr 2, 2018 15:42:49 GMT -5
Post by Delpzie on Apr 2, 2018 15:42:49 GMT -5
Guys currently i have 132-160 main jets , do u think that will cut it or it will need bigger main jet ? I need to wait now 4 weeks for my scooter attack order , and if the jet doesnt cut it then i will need to wait another 30 days.... what do u think will it be enough or i should just order from now 162-190 set , carb is 28mm pwk.
Baotian
Apr 6, 2018 17:37:28 GMT -5
Post by spaz12 on Apr 6, 2018 17:37:28 GMT -5
Little late to the party, but I would have told you to get all that you can afford. Always better to have it then need it.
Post by Delpzie on Apr 7, 2018 13:12:27 GMT -5
Yea yesterday i ordered 165-192 hopefully will be enough.
Baotian
Apr 22, 2018 20:16:10 GMT -5
Post by Delpzie on Apr 22, 2018 20:16:10 GMT -5
Hey guys i got malossi overrange torque pulley but cut down to 124mm and also has made holes in it, now i know there is 2 washers in the overrange set that seperates the bell a little bit from the pulley does anyone know how thick they are i cant seem to find information ? I will need to make those 2 washers cuz the guy i bought from the pulley doesnt have them. Also how wide the belt needs to be for overrange set 17,5mm or 18mm ? I will be buying malossi kevlar belt 769x18mm from peugeot.
Post by ryan_ott on Apr 22, 2018 20:40:32 GMT -5
Baotian
Apr 22, 2018 21:14:55 GMT -5
Post by Delpzie on Apr 22, 2018 21:14:55 GMT -5
Baotian
Apr 29, 2018 14:04:59 GMT -5
Post by Delpzie on Apr 29, 2018 14:04:59 GMT -5
Guys do u know if aerox 100cc and the 50cc version have the same engine blocks ? Im asking this for the belt size cuz i wanna buy polini kevlar belt for 100cc aerox so if its the same blocks the belt will fit nicely on the 124mm pulley with the overrange vario. I think its the same blocks right just aerox 100cc has bigger vario and pulley and longer gears or im wrong ?
Post by Delpzie on May 15, 2018 16:13:30 GMT -5
So a little update , pretty much scooter-attack screwed my project and delayed it for 6weeks, i oredered gaskets for the modular version of my kit but even after 4 weeks that they said they should have them, they answer me that they still havent gotten them with the latest orders, so i decided to not lose more time and i ordered gaskets for regular head s6 racing kit, they finally arrived 5 days ago. Along with koso thermometer,voltmeter, egt sensor from aliexpress and some other stuff. Next thing i ordered are the bearings polamid FAG C4 and FAG NJ204 cylindrical roller bearing, the bearings should be here tomorrow, i just need to get belt and thats it these days we will start assembling the engine along with porting the engine blocks and the cylinder. Kinda excited i expect it to be real monster, i will maybe even have a chance to take it on dyno after we fine tune it all.
Post by Delpzie on May 17, 2018 23:26:38 GMT -5
Bearings are here
Baotian
May 19, 2018 4:43:10 GMT -5
Post by Lucass2T on May 19, 2018 4:43:10 GMT -5
You are going to use roller bearings on the crankshaft? I've never seen that actually, probably for a good reason too...
Post by Delpzie on May 19, 2018 7:40:12 GMT -5
Yes these are for the crankshaft,scooter attack says they give increased stability to the crankshaft to counter and minimize loss of power which is true this one will go on the cvt side it will take much more beating than standard bearing. Also i will check the crank and re-balance it in 0 because the new kit is stronger, the crank is new not even 80kms on it but just to be sure i will do it, it doesnt cost me much.
