lenny
Scoot Newb
Post by lenny on May 28, 2021 3:20:30 GMT -5
I Bought a taotao pony and i pulled the motor right off the bat and installed the naraku HD crank and a 101octane 72cc 47mm jug and a non egr stock 64mm valve head with a naraku racing cam. I am waiting for a set of rocker arms because the motor came with a 69mm valve head, so when i get that taken care of i can report in how well the motor does. I also used a 101 octane bolt kit, so every bolt is higher quality and torqued/blue loctited. It "should" last a while. Naraku HD crank 101octane 47mm jug 101octane non egr 64mm valve head naraku racing cam pd19j carb 100 jet stock exhaust K&N cone filter NGK cr7hix plug Mileage 100km (atm) What speeds are you able to get?
