Post by spazter12 on Dec 29, 2018 16:47:19 GMT -5
Color is close. The bad news is that waffle is so low a plate wont fit in that spot. Noooooooo. Damn I didn't even thing about that. I forgot its not stretched.
Post by Happypancake! on Dec 29, 2018 16:58:58 GMT -5
No worries
Post by lilpinny on Dec 29, 2018 17:33:15 GMT -5
The best, most solid, hang your license off the engine thing I have ever used is the one from Drow. All the others have broken off. The Drow one only hangs on by one bolt, so you can mount it on anything, and it’s solid.
Post by lilpinny on Dec 29, 2018 17:35:06 GMT -5
Post by Happypancake! on Dec 29, 2018 18:51:53 GMT -5
Currently have the PWJDM one
Post by lilpinny on Dec 29, 2018 19:54:42 GMT -5
On a 50 it might not matter much, but I've lost two plates on my 170 cause it shook that thing off. Fucker snapped right off.
Post by Happypancake! on Dec 29, 2018 19:58:03 GMT -5
On a 50 it might not matter much, but I've lost two plates on my 170 cause it shook that thing off. Fucker snapped right off. I agree, those GY6’s do RaTtLe a lot
Post by magoconnor on Feb 7, 2019 19:31:04 GMT -5
Hello. Where did you get those cool looking stickers? Cheers Mag.
Post by Happypancake! on Feb 7, 2019 19:43:13 GMT -5
Somebody from FB. I don't remember who though.
Post by ciridae on Feb 15, 2019 9:47:10 GMT -5
Happypancake,
What shock do you run on your Mets? I picked up an 07 yesterday for my wife and the old shock is a dead, thought I’d upgrade it for her. I was looking at the mnnthbx met shock mount and going with a ruck shock. Any experience with those?
Post by Happypancake! on Feb 15, 2019 10:28:29 GMT -5
Post by ciridae on Feb 15, 2019 11:11:06 GMT -5
Does that metruck have a stretch or is it stock length from the rear ruck frame? Do you know if that shock would fit on a stock met? I don’t want to go too low, the wife doesn’t like the low look. Once I fix her old scoot I get to play with the met afterwards Thanks for the help!
Post by Happypancake! on Feb 15, 2019 11:15:01 GMT -5
Metruck is not stretched. Stock.
Shock will fit w/ the adapter. Some of the aftermarket shocks have a wider upper mount and will only work w/ stretches.
Post by ciridae on Feb 15, 2019 15:01:52 GMT -5
I ordered the adapter and shock, should be in next week.
Post by datni99ahern on Mar 4, 2020 12:42:58 GMT -5
Remember your bikes from the Old TR forum. Glad some of the members have jumped over. Noticed you we’re running NB50 gears. Was curious, did you have to run the drive/clutch shaft as well?
