Post by Happypancake! on Jun 22, 2018 20:32:17 GMT -5
What paint brand?
Post by spazter12 on Jun 22, 2018 20:57:14 GMT -5
Rust-Oleum. I had painted it when I first did the swap and didn't want to have it look busted if I just repainted the area around the welded bung. It held up really well for two years more or less.
Post by spazter12 on Jun 24, 2018 16:22:33 GMT -5
Got the OKO installed with the new clocking flange and the new intake manifold. Blocked the intake vacuum since I'm using the stock ruckus pump, not a Mikuni. Took a bit to start up and after getting it to run I took it around the block....or tried to. Half way around the block it died....again and didn't turn back on. I had to push it back to the house which in 95°F and Houston humidity it felt like I was swimming. Needless to say I wasn't a happy camper.
Post by lilpinny on Jun 24, 2018 16:35:54 GMT -5
I'd duct tape a mikuni in there and bypass your old fuel pump.
Post by spazter12 on Jun 24, 2018 16:36:50 GMT -5
I'd duct tape a mikuni in there and bypass your old fuel pump. I'll have to wait until next month but that's where I was heading
Post by lilpinny on Jun 24, 2018 16:45:51 GMT -5
I'll.send you a brand new one if you buy me a brand new ok one
Post by spazter12 on Jun 24, 2018 16:48:24 GMT -5
Sure.ill send it your way mid July if that's ok
Post by lilpinny on Jun 24, 2018 16:49:07 GMT -5
Send me your Addy again via slack
Post by Tanuki on Jun 25, 2018 0:48:02 GMT -5
Now thats love!
Post by spazter12 on Jun 25, 2018 1:21:14 GMT -5
Now thats love! From one king to another, brotherly love 🤙🏼
Post by spazter12 on Jun 29, 2018 21:58:43 GMT -5
Thanks for the mikuni lilpinny! 🤙🏼 I should have some time next week to install this bad boy. I'll send you one back in a few weeks.
Post by Trigger1212 on Jul 7, 2018 19:54:45 GMT -5
Spatzer
One thing that I'd do is drive your bike with the gas cap loose. The cap may not be venting properly and pulling a vacuum and not letting the fuel flow through at higher throttle. Bit of a long shot but it IS possible AND it will not cost you anything. Give it a shot and let us know if it made any difference. Do it before putting in the Minuki pump.
Good Luck, this type of issues are just a monumental PITA, really aggravating and in the end it is usually something simple/stupid, one of those "why didn't I think of that sooner deals". But in the end you just happy as hell you have figured it out!
Cheers!
Wade
Post by spazter12 on Jul 7, 2018 20:04:36 GMT -5
Spatzer One thing that I'd do is drive your bike with the gas cap loose. The cap may not be venting properly and pulling a vacuum and not letting the fuel flow through at higher throttle. Bit of a long shot but it IS possible AND it will not cost you anything. Give it a shot and let us know if it made any difference. Do it before putting in the Minuki pump. Good Luck, this type of issues are just a monumental PITA, really aggravating and in the end it is usually something simple/stupid, one of those "why didn't I think of that sooner deals". But in the end you just happy as hell you have figured it out! Cheers! Wade Damn! I literally installed the mikuni earlier today. I'll keep that in mind tho if it happens again I'll give it a try. Thanks for the tip Wade, I really appreciate it 🤙🏼
Post by Tanuki on Jul 8, 2018 11:22:43 GMT -5
Its dry now. Go ride the damn thing
Post by spazter12 on Jul 8, 2018 11:38:42 GMT -5
At the pool with my daughter. I'll take Roxie on a spin when she goes down for her nap
