Post by james82nd on Feb 15, 2018 19:44:47 GMT -5
I had the same issues but have yet to install the new stator just the voltage regulator which was good and with corrosion
I also found running a double ground wire helps alot
Post by dexameth on Feb 15, 2018 20:23:11 GMT -5
I also found running a double ground wire helps alot I've been hearing a stronger battery to frame ground will help. I get to play around with it because I FINALLY have a day off tomorrow.
Post by dexameth on Feb 15, 2018 20:27:22 GMT -5
I gotta clear up my previous post about the regulator rectifier. I thought I was on a different topic on my 150s electrical problem... haha yeah both scoots are hating me for some reason. All I do is love them.
I replaced the stator on the scoot with the corrosion I showed, but... haven't cleaned the corrosion yet. I know, I know. I scooted a good amount and the next day pop the charger on. Takes no time to go to full charge. Could have been a bad stator but I'm still gonna clean the crud tomorrow as well as tackle the 150s issue.
