Post by benji on Apr 22, 2018 19:50:13 GMT -5
the 5-ply is too soft to really get into the crevices. 60 grit or gtfo I use microfiber towels. Crazy hard to flush though.
Post by boostcrzy on Apr 22, 2018 21:36:15 GMT -5
I’m making 25hp with my 70cc. What type of machine work was needed to get the 2fast cylinder working? How many hours between top ends? Case is bored and ported/trenched. I’m still on the first top end with about 20hrs on it. I pulled the top end apart last week to inspect and it’s like new. So it went back together and is still running perfectly. I also put the scooter back on the Dyno to check power and it’s still at 25hp. No problems at all.
Post by hellish100 on Jul 4, 2018 19:50:53 GMT -5
Engine mount breakthrough: After a few beers and starring at the frame I found a way besides eye-balling the motor mount. Step 1: cut off the original bottom mount. Step 2: there are two holes on the seat mount that I wanted to use. These holes I’m using as fixed points to build a template off of to locate the stock zuma engine hanger. This guarantees that the hanger will be level in x,y,z axis. I just have to make one more for the other side then start making links for the mount.
Post by hellish100 on Jul 29, 2018 13:53:44 GMT -5
Post by hellish100 on Aug 23, 2018 8:50:51 GMT -5
Post by hellish100 on Sept 3, 2018 19:24:50 GMT -5
Post by lordverminaard on Sept 4, 2018 9:04:46 GMT -5
that thing is gonna be bonkers!
Post by hellish100 on Jul 16, 2019 23:47:25 GMT -5
Update Finally! Time to get back on the horse after concentrating on career and home stuff.
Post by houseoffubar on Jul 18, 2019 14:30:22 GMT -5
OK, I’m in! After all the fab work and minimalist design, I’m sold😊 I’m also a fabricator, so really liking the work so far!
Post by hellish100 on Jul 18, 2019 21:58:53 GMT -5
OK, I’m in! After all the fab work and minimalist design, I’m sold😊 I’m also a fabricator, so really liking the work so far! Thank you! Minimalism is the name of the game. The next big item is getting the motor built but there are a bunch of small things I can tackle and update with along the way.
Post by hellish100 on Oct 3, 2019 6:16:47 GMT -5
Ordered new base and head gasket. Bought a cheap no-name expansion chamber off a local scooter friend. Threw a 70main and 30idle jet in my 21mm del. It ran, even over-carb'd!
Post by hellish100 on Jan 27, 2020 9:33:46 GMT -5
The Polini Corsa and C16 were originally intended for my Venice build. I used the parts to finally put together the Razz. I have a lot left to do but it's a wild animal. I was not expecting that type of acceleration from a 70. It feels like the CR85 I had as a kid. Next plans: Install the CHT gauge and inspect the temps during tuning.
Post by hellish100 on Feb 16, 2020 9:38:08 GMT -5
I fired it up for the 2nd time yesterday after smartly installing the trailtech CHT gauge. It’s a pricey cylinder so I’d really prefer to not melt it.
So, now I know I’m rich but didn’t know to what extent. I’m running a kart style air filter and it runs better without it. With the filter on, it just bogs and will not take off.
Without the filter, the razz will lift the front wheel mid throttle.
During 5 minutes of ride time, the CHT only got up to 195 F. Knowing now that it runs better without the airfilter also confirms that even leaning it out with no filter, I’m still pig rich.
Next I’ll drop the needle and go down from a 96 to a 90, throw the filter back on and try it again. I highly recommend the gauge to anyone!
Post by Zino on Feb 16, 2020 9:54:06 GMT -5
Nice work Hellish . Better get used to riding on one wheel all day long .
Post by 2stroked on Feb 16, 2020 11:20:48 GMT -5
Nice Job Hellish. Looks sick. Kind of makes me wanna ... Nope....
