Post by Mech Warrior on Jul 8, 2020 21:32:40 GMT -5
Well it can be several issues for starts check condition of your spark plug if you are running too rich maybe flooding and wont start or too lean and getting too high air intake to gas ratio , also check your vacuum line make sure its connected then you can check all your ground wire connections maybe upon installation of new battery something became loose or disconnected causing the scoot to intermittently run for short periods or unpredictable long periods then shutting off , you may also like to clean your carburetor and properly adjust jetting if needed.
Post by GrumpyUnk on Jul 9, 2020 7:12:48 GMT -5
Mech, are you running short on periods? I can send you some.
Here:
I don't need them. tom
Post by Mech Warrior on Jul 9, 2020 13:12:27 GMT -5
No thanks my wife has enough
