Post by harleyracer59 on Aug 11, 2018 17:51:31 GMT -5
one more interesting thing ive found is a honda 40x39.6 Honda 41x38 and Yamaha 40 bore all have 10mm wrist pins and a within .5-1mm in height and pin location. with both 40mm being almost identical. ill post some pics later
Post by yanto32 on Feb 20, 2021 13:38:50 GMT -5
I just bought the same cylinder for my Stream, super excited to get it as it was a mission to find something with the same port fitting (hoping this will be, or as close as i can get), was wondering if you have any idea what piston I could use?. So far all I've found is 12mm pin versions, but as the stream is 10mm im a little concerned i'm going to have to try and find a new conrod, and then that means more modification. any help would be very appreciated.
