Sorry, I was out most of yesterday or I would have posted earlier. I'll show my math here as I check so anyone can see if I mess something up or get it right. Just woke up so who knows how it will go. lol
First, figuring out the displacements. I'm going to use the measured stroke of 51.8mm. Advertised stroke is usually so close to what I measure with the Minarelli engines that I've done that I assume the slight error is mine and just go with advertised stroke. In this case it's significantly off.
Displacement = ( (Bore Radius Squared x 3.14159) x Stroke ) / 1000
Displacement = ( (25² x 3.14159) x 51.8) / 1000)
Displacement = ( (625 x 3.14159) x 51.8) / 1000)
Displacement = (1963.49375 x 51.8) / 1000
Displacement = 101708.97625 / 1000
Displacement = 101.70897625cc or rounded to 101.71ccTo be sure it's all covered, I did the same process using 52.6mm advertised stroke and that gave me 103.27977125cc. So your displacement is either about 101.71cc or 103.28cc. I'd assume the former and will use it for future calculations.
Next, I'll do the corrected displacement. Displacement above the exhaust port basically. The reason that you get the same numbers for corrected and different numbers for uncorrected is that you only have 1 number to work with for corrected. You have 2 different strokes listed, so that will change the uncorrected ratio any time you change the stroke.
You'll notice I used 27.5mm here and not 28mm listed for exhaust port depth. You should know the actual stroke above the exhaust port for this measurement. Not just the depth. You want to know how much volume the piston is displacing, not just how much volume is above the piston to the cylinder deck. I think my old equations were a little off because I wasn't accounting for this when I wrote the displacement thread. Corrected cylinder displacement and volume would be 2 different specs unless you have 0 deck, where the piston sits right at the cylinder deck. Then it gets easier and both are the same number. In this case, the piston sits 0.5mm below the cylinder deck, so I subtracted 0.5mm from the 28mm exhaust port below deck number to get an actual stroke above the port of 27.5mm. The other 0.5mm above deck is part of the trapped volume that gets calculated later, the same for both corrected and uncorrected numbers.
Corrected Displacement = ( (Bore Radius Squared x 3.14159) x Stroke Above Exhaust Port ) / 1000
Corrected Displacement = ( (25² x 3.14159) x 27.5) / 1000
Corrected Displacement = ( (625 x 3.14159) x 27.5) / 1000
Corrected Displacement = (1963.49375 x 27.5) / 1000
Corrected Displacement = 53996.078125 / 1000
Corrected Displacement = 53.996078125cc or rounded to 54.00ccBTW, I'm rounding to 2 decimal places for easier "handling" of the numbers. I don't think any of us are capable of measuring in a way that would make beyond hundredths necessary.
Now to find piston crown displacement.
Piston Crown Displacement = Calculated Volume - Actual Volume
Piston Crown Displacement = ( ( (Bore Radius Squared x 3.14159) x Piston Depth Below Deck As Tested ) / 1000 ) - 7.67cc
Piston Crown Displacement = ( ( (25² x 3.14159) x 5.15) / 1000 ) - 7.67cc
Piston Crown Displacement = ( (1963.49375 x 5.15) / 1000 ) - 7.67cc
Piston Crown Displacement = (10111.9928125 / 1000 ) - 7.67cc
Piston Crown Displacement = 10.1119928125cc - 7.67cc
Piston Crown Displacement = 2.4419928125cc or rounded to 2.44ccNext I'll calculate volume above the piston to deck. I didn't show all steps for the calculations that have already been done numerous times.
Volume Above Piston To Deck = ( (Bore Radius Squared x 3.14159) x Piston Depth Below Deck ) / 1000
Volume Above Piston To Deck = (1963.49375 x 0.5) / 1000
Volume Above Piston To Deck = 981.746875 / 1000
Volume Above Piston To Deck = 0.981746875cc or rounded to 0.98ccNow I can find the trapped volume.
Trapped Volume = ( Combustion Chamber Volume + Head Gasket Volume + Volume Above Piston @ TDC To Deck ) - Piston Crown Displacement
Trapped Volume = (7.67 + 0 + 0.98) - 2.44
Trapped Volume = 8.65 - 2.44
Trapped Volume = 6.21ccFinally, I can get to finding the compression ratios; beginning with uncorrected compression ratio.
Uncorrected Compression Ratio = (Displacement + Trapped Volume) / Trapped Volume
Uncorrected Compression Ratio = (101.71 + 6.21) / 6.21
Uncorrected Compression Ratio = 107.92 / 6.21
Uncorrected Compression Ratio = 17.37842190016103 or rounded to 17.38:1That sounds extremely high, but you've got a huge cylinder volume and a small combustion chamber with very little volume above deck. The combustion chambers on most of my 90cc stuff are 10cc and above and yours is 7.67cc, which is more similar to what I'd expect with a 70cc engine.
Now corrected.
Corrected Compression Ratio = (Corrected Displacement + Trapped Volume) / Trapped Volume
Corrected Compression Ratio = (54 + 6.21) / 6.21
Corrected Compression Ratio = 60.21 / 6.21
Corrected Compression Ratio = 9.695652173913043:1 or rounded to 9.70:1So to make long math short; CR = 17.38:1 and CCR = 9.7:1 by my calculations.
I'm pretty much on with what Scott came up with. CCR is probably off because of the 0.5mm stroke difference mentioned earlier that I'm guessing he used.
All of those sound really high for something that doesn't spark knock like crazy to me. 195psi is a high compression test reading too though. I'm curious. Is it a coincidence that your combustion chamber measurement and volume above piston for the crown displacement are both 7.67cc or did a number get entered somewhere it shouldn't have? It happens, but seems unlikely to get to the hundredth of a cc exact on both of those so I was wondering if maybe we had an input error to throw things off. EDIT : Nevermind. I just went back and looked and realized you said both numbers just happened to be the same. Hmmm.
John's numbers sound like reasonable figures for something that runs well... I'm just not sure what is done different in the math.
I got 12.77 uncorrected,7.34 corrected..Double check me though!!!
BTW, don't feel bad
oldgeek. I started this post at 5:30-5:45AM and it's now 7:30AM.
Are we having fun yet?
