jack667
Post by jack667 on Nov 29, 2018 15:31:10 GMT -5
I see nobody pointed out here , those two inlet`s on the carb should be blocked out. I'm not familiar with this carb so I didnt mention it. Seems like theres 3!? That's the most I've seen on a carb. I just got in another one of these. In the first photo, you see the gas line with the larger diameter opening and the oil vaccum with the small opening. And then in the 2nd photo, there are those 3 pipes on the side. One comes covered and that's for the oil and the other two. My eyes aren't good enough to see into them...
Post by 190mech on Nov 29, 2018 18:47:37 GMT -5
Post by Delpzie on Nov 30, 2018 21:00:11 GMT -5
It’s a coolant passage for water cooled bikes. If it were vacuum fittings yes block them off but they don’t go into the carb itself, just the casting to keep warm, either for emissions bs or carb freezing so I don’t see a real need to block off. Yes its for the coolant passage and yes u need to block it off! EDIT: Just put one hose connect them together.
