Post by scooternub on Oct 20, 2018 8:04:21 GMT -5
Awesome, I want to change the belt too, and this is awesomely perfect.
Post by scooternub on Oct 20, 2018 8:09:22 GMT -5
Also I am missing a cvt cover allen key bolt, any recommendations for a replacement? If needed, let me know, I'll take one out and measure it.
Post by scooternub on Oct 20, 2018 8:56:49 GMT -5
Post by geoffh on Oct 20, 2018 9:17:03 GMT -5
That,s M6x25 any hardware shop should have a bolt to replace it but if it,s just 1 missing don't,t sweat it.
Post by scooternub on Oct 20, 2018 9:34:31 GMT -5
That,s M6x25 any hardware shop should have a bolt to replace it but if it,s just 1 missing don't,t sweat it. Geoff I noticed when I was taking that metric bolt out that there's a gap between the CVT cover in the block or transmission block its supposed to have a gasket can someone point me to a website that would have that exact match of a gasket for my CVT cover because I'm going to be riding this in the winter time I don't really want salt and water getting up into the CVT.
Post by 90GTVert on Oct 20, 2018 9:42:25 GMT -5
Post by scooternub on Oct 20, 2018 10:33:43 GMT -5
You guys are awesome. I really appreciate the help. Ima get a couple of the gaskets as I am sure in time they stick and tear and degrade. Really grateful.
Post by niz76 on Oct 20, 2018 11:02:34 GMT -5
I've had a bunch of Adly scoots and they're nice. Basically a stretched out shortcase like others have mentioned (uses shortcase gears and a long Adly specific belt.) Here's my "dirt scoot" Adly w/70cc Airsal T6 and Malossi Wild Lion exhaust...
Post by scooternub on Oct 22, 2018 6:42:39 GMT -5
For this gearbox, im sure oil needs to be changed. I changed the oil in the gearbox bof my old sunmy scooter. I forget what kind of oil it takes and how much, do you guys know the info for this on this gearbox? And what sux is, the shit is expensive and i have left over oil at my parents house but cant get to it till Thanksgiving.
Post by niz76 on Oct 22, 2018 11:55:55 GMT -5
Right or wrong I've been using Mobil1 75w 90. 100ml.
Post by scooternub on Oct 22, 2018 12:17:00 GMT -5
Right or wrong I've been using Mobil1 75w 90. 100ml. Thats it, rings a bell, damn I have half a bottle hour vehicle drive away. Gah. Would you know how much goes in for my gearbox? I checked for engine model # and can't find one. Another words if I find the model # of the engine I can search most of this stuff myself. Any suggestions where the # might be and how much gearbox oil for the stretched shortcase engine gearbox?
Post by niz76 on Oct 22, 2018 12:23:24 GMT -5
Yep it's 100ml. 100 Milliliters. The bottle is marked on the side so you can put the correct amount in. I've actually added too much before and had it sling out so try not to add too much!
Post by scooternub on Oct 22, 2018 12:29:38 GMT -5
Yep it's 100ml. 100 Milliliters. The bottle is marked on the side so you can put the correct amount in. I've actually added too much before and had it sling out so try not to add too much! OHH, awesome, I thought the bottle was 100ml, brain fart. That is perfect, thank you so much. Ima run to autozone and hope the bottle isn't $25 bucks. And pick up an oil pan with a drain port. "working without a garage/shop and my snapon creeper sux".
Post by scooternub on Oct 22, 2018 12:37:38 GMT -5
12.99 a qt
Post by niz76 on Oct 22, 2018 13:08:54 GMT -5
BTW your engine id is stamped on the case about 6 inches to the left of your gear oil fill screw. This is the engine ID location on pretty much all scoot engines. Probably mucked up and need to be cleaned off to see it. This pic is from an Adly engine exactly the same as what you have. I wouldn't put too much stock into that ID tag though- probably won't get you much info on Google. Refer back to the info that 90GTvert posted on page 1 for what to search for when looking for parts... There's a few parts that are somewhat different than the typical Jog engine (Jog, Minarelli horizontal, 1e40qmb, etc.) such as the flywheel and stator but for the most part it's just another "Minarelli horizontal" or "Jog" or "1e40qmb" engine so there's tons and tons of parts available. If you have any questions when buying parts just ask and we can help!
