Post by scooternub on Feb 3, 2019 10:31:59 GMT -5
Main jet size is a number 75.
Post by scooternub on Feb 3, 2019 10:41:59 GMT -5
The thread size for the main jet is 5 mm.
Post by scooternub on Feb 26, 2019 12:16:09 GMT -5
Hey fellow members does 21mm sound about the right size for the nut on the back that holds the rim on? That's what I measured the nut with a millimeter tape measure it looks to be 21mm.
Reason being I am going to go buy a socket today.
Post by scooternub on Feb 28, 2019 8:30:27 GMT -5
Hey fellow members does 21mm sound about the right size for the nut on the back that holds the rim on? That's what I measured the nut with a millimeter tape measure it looks to be 21mm. Reason being I am going to go buy a socket today. Actually, i have standard 1/2 inch deep well set and thinking it was metric decided to try the standard set and 7/8 fits.
Post by benji on Feb 28, 2019 9:35:30 GMT -5
Hey fellow members does 21mm sound about the right size for the nut on the back that holds the rim on? That's what I measured the nut with a millimeter tape measure it looks to be 21mm. Reason being I am going to go buy a socket today. Actually, i have standard 1/2 inch deep well set and thinking it was metric decided to try the standard set and 7/8 fits. 7/8's is 22.2mm, so I'm sure a 22mm metric nut would fit in one well, especially after plating. I have a set of standard sockets at work that actually have the metric conversion engraved on the socket. Some are pretty close. Some aren't haha.
Post by scooternub on Feb 28, 2019 9:50:17 GMT -5
Actually, i have standard 1/2 inch deep well set and thinking it was metric decided to try the standard set and 7/8 fits. 7/8's is 22.2mm, so I'm sure a 22mm metric nut would fit in one well, especially after plating. I have a set of standard sockets at work that actually have the metric conversion engraved on the socket. Some are pretty close. Some aren't haha. Wow, thanks! That would have sucked to round the corners. Saved a huge problem.
Post by scooternub on Apr 10, 2021 16:40:51 GMT -5
hey guys my exhaust on my 2008 adly hammerhead is old and has a whole in the exhaust near where it connects to the engine. if we get a fourth stimulus check I'ma get a new scooter a genuine rough house sport do you guys think it's worth replacing the old exhaust on the adly at the price of $215 plus tax and shipping? I do not think I want to sell the adly if I get the genuine I was thinking about jumping into doing my own work on my adly. should I wait and see how it goes with new scooter then working on the adly as a project then I don't have to worry about screwing up my only scooter if I get the new scooter. I'd like to know what your thoughts are please. www.ajpartsstore.com/schematics/scooter-parts/scooter-parts-silver-fox-50-2-stroke/silver-fox-50-2-stroke-exhaust
df41590
Post by df41590 on Apr 10, 2021 17:48:12 GMT -5
Get an aftermarket they're cheaper and you gain some performance, scootertuning.ca has a Technigas Silent Pro for 119.99 + 15 for shipping, you'll need to grab some jets the few steps above what you have now.
Post by scooternub on Apr 10, 2021 17:57:50 GMT -5
Get an aftermarket they're cheaper and you gain some performance, scootertuning.ca has a Technigas Silent Pro for 119.99 + 15 for shipping, you'll need to grab some jets the few steps above what you have now. oh cool. how would I know what jet size I would need if I bought a set of jets at different sizes with a new exhaust that you're talking about for 119? would it have less performance if it's wrong size would it bog out die out what would it do if the jet sizes too small or too big? in other words how do I find out what the right size is?
df41590
Post by df41590 on Apr 10, 2021 18:22:45 GMT -5
Up to 10% bigger. So i'd grab a mid upper 70's, an 80, and a mid lower 80s one. Start with the biggest and move down. These guys sell quality jets and have a guide to make sure you are buying the correct style. www.jetsrus.com/FAQs/FAQ_identify_that_jet.htmIf you run on too small a jet you'll be running lean, have a bog(same w/ too big a jet) and potentially overheat the engine, the performance exhausts will come with a restriction(looks like a washer) in the mouth of the exhaust where it bolts to the cylinder make sure to remove this. A temp gauge will really help out with tuning, and I think it is essential for beginners to carb tuning. Aim for a top temp after sustained WOT around 350*F.
Post by scooternub on Apr 12, 2021 9:50:54 GMT -5
I thought a helicopter was over me when I was doing about up there, and I come to the stop sign and I'm like well this seems loud as hell I look underneath well look at the picture.
the exhaust blew š¤£š
Post by scooternub on Apr 12, 2021 9:56:06 GMT -5
Get an aftermarket they're cheaper and you gain some performance, scootertuning.ca has a Technigas Silent Pro for 119.99 + 15 for shipping, you'll need to grab some jets the few steps above what you have now. Will the Technigas Silent Pro fit on a 2008 adly hammerhead?
Post by scooternub on Apr 12, 2021 10:00:17 GMT -5
Get an aftermarket they're cheaper and you gain some performance, scootertuning.ca has a Technigas Silent Pro for 119.99 + 15 for shipping, you'll need to grab some jets the few steps above what you have now. Will theĀ Technigas Silent Pro fit on a 2008 adly hammerhead? I believe this is the right one? www.scootertuning.ca/en/exhaust-systems-50cc-70cc/3000101-tecnigas-silent-pro-exhaust.html I'll get it if it's the right one it says Minarelli. i have the 2008 adly hammerhead Minarelli engine.
Post by scooternub on Apr 12, 2021 10:14:36 GMT -5
that jet site dont have minarelli.
df41590
Post by df41590 on Apr 12, 2021 11:21:41 GMT -5
Won't be under minarelli Look for a manufacturers stamp on the side of carb, not sure what carb an Adly has stock. You could also pull the main jet and compare it to the pictures/measurements they provide.
