Post by milly on Nov 20, 2018 11:13:16 GMT -5
I need to skim down the outside of my cylinder sleeve by 1 mm. I have been given access to a lathe and the barrel fits the chuck ok and turns without hitting anything. The only thing that touches the cylinder as I traverse the tool back and forth will be the carriage. My question is how far can I angle the cutting tool back towards the machine in hope to gain enough clearance or not as the case may be. Thank you
Post by gsx600racer on Nov 20, 2018 13:13:30 GMT -5
Turn the compound perpendicular(or as close as you can)to the cylinder. Most are set at an angle. That should buy you some room. You can also extend the tool, just have to be careful of vibration or chatter.
Post by milly on Nov 20, 2018 13:50:33 GMT -5
Post by FrankenMech on Dec 1, 2018 7:54:14 GMT -5
I hope it fits OK. It looks like you needed to indicate the cylinder in before cutting to make the cut even.
Post by milly on Dec 2, 2018 17:35:01 GMT -5
I did say to the chap fitting it to give me a shout and I would take it down some more but instead he dremelled the cases with it all still in the scooter, changed the oil and advised I change oil again. Told me this after I paid him and was about to ride off. Next day changed oil, lots of Ali swarf in oil filter cap and the saucepan I drained it in looked like it had a metal flake coating when I had drained that. Next I put flushing oil in and drained that oil looked ok then. Hopefully nothing has been damaged by all the swarf pumping around. I won't be going back there again.
Post by aeroxbud on Dec 2, 2018 19:29:21 GMT -5
That's not very professional of them.
Post by FrankenMech on Dec 2, 2018 22:07:05 GMT -5
All that swarf has ruined the bearings.
Post by twinjogs on Dec 4, 2018 12:37:53 GMT -5
Sorry I missed this back in Nov. But for others...a 3 jaw chuck is for holding round "stock" close to center not on-center. A 4 jaw chuck with soft jaws or soft shims to protect the finished bore is what is needed here, allows truing to center with a dial indicator. I have had good luck with a 1.5" boring bar to reach in near odd shaped spinning parts. You did your best, it was probably good enough.... until the fitter hack got a hold of it. Sorry to hear that.
