Post by sToRm on Jan 30, 2019 12:24:03 GMT -5
*UPDATE*
In accordance with the usual Ruck build protocol, There has been a slight deviation from the original game plan.
Post by sToRm on Feb 5, 2019 12:18:19 GMT -5
Plan B
Polished Handlebars & Stem.
Shiny Split 5 Spoke Wheels. Lowered Headlights.
Post by sToRm on Feb 5, 2019 20:32:08 GMT -5
R6 Tail light installation. LED integrated tail light and turn signal. Mojo Customs R6 mounting plate. Drilled a hole to route the wires. Male bullet connectors crimped on. Mounting the plate to the underside of the seat using self tapping screws.
Installation complete.
dotdash
Post by dotdash on Feb 6, 2019 7:46:44 GMT -5
Taillight looks good!
By chance, did you put a screw at top of the tail light? It would have to go into seat frame or something, not the bracket. My light dips a bit because I haven't done it yet, just not sure what type of screw to use or maybe do something else.
Post by sToRm on Feb 6, 2019 18:00:31 GMT -5
Taillight looks good! By chance, did you put a screw at top of the tail light? It would have to go into seat frame or something, not the bracket. My light dips a bit because I haven't done it yet, just not sure what type of screw to use or maybe do something else. I drilled a tiny hole in the seat pan and used a super short 12x1/2inch screw with a rubber washer(from Lowes). You could also use 3M double sided tape like the kind used on GoPro mounts.
Post by sToRm on Mar 4, 2019 18:09:01 GMT -5
Post by sToRm on Mar 4, 2019 18:10:55 GMT -5
