Post by Happypancake! on Mar 14, 2019 7:16:10 GMT -5
Yeah. No variator boss. It also has a small “cage” around the rollers. Clutch and variator on the crank.
Post by Happypancake! on Mar 15, 2019 12:42:35 GMT -5
Sneaky place for the carb.
Post by Happypancake! on Mar 15, 2019 15:03:58 GMT -5
Stock pipe
Post by Happypancake! on Mar 15, 2019 15:43:35 GMT -5
Engine out Screws on intake were finger tight. PA50I top intake and reeds vs PA50II btm Need to drill a hole in case to GET PA50II reed block to fit
Post by Happypancake! on Mar 15, 2019 16:04:03 GMT -5
Stock 40 mm piston. DR Kit 46 mm piston.
Post by harleyracer59 on Mar 15, 2019 17:13:39 GMT -5
Engine out Screws on intake were finger tight. PA50I top intake and reeds vs PA50II btm Need to drill a hole in case to GET PA50II reed block to fit other option would be to grind off that locating pin. does yours have gears? 2 or 3 speeds? I thought one hobbit had a separate transmission.... idk
Post by Happypancake! on Mar 15, 2019 17:42:56 GMT -5
Engine out Screws on intake were finger tight. PA50I top intake and reeds vs PA50II btm Need to drill a hole in case to GET PA50II reed block to fit other option would be to grind off that locating pin. does yours have gears? 2 or 3 speeds? I thought one hobbit had a separate transmission.... idk It’s has a variator. Infinite gears
Post by Happypancake! on Mar 15, 2019 17:46:27 GMT -5
50cc 4t vs 2t size
Post by Happypancake! on Mar 25, 2019 19:35:07 GMT -5
Drilled 7mm hole to accept PA50 reed block. Test fit.
Post by spazter12 on Mar 27, 2019 9:13:42 GMT -5
Drilled 7mm hole to accept PA50 reed block. Test fit. 🐍
Post by Happypancake! on Mar 28, 2019 19:51:53 GMT -5
Seems like I’m going to always need to keep the tank more that half full......
Post by Happypancake! on Mar 28, 2019 22:56:51 GMT -5
Weird ass cages around the variator weights. They kind of restrict movement. Therefore....NOT NEEDED!
Post by harleyracer59 on Mar 28, 2019 23:15:18 GMT -5
Seems like I’m going to always need to keep the tank more that half full...… you could always run a fuel pup or a walbro or tilston with a built in pump?
Post by Happypancake! on Mar 29, 2019 16:07:34 GMT -5
All back together. I'll need to order a longer throttle cable. Tires are shot. Probably should GET new ones before i hit speed runs. Oh. I did check the Honda TDC timing mark and It's spot on.
Post by Happypancake! on Mar 30, 2019 16:59:58 GMT -5
Boiiiiiiiiig.....
