Post by jackrides on Jul 7, 2019 14:23:30 GMT -5
Great looking mags and a drum brake? Supercool!
Post by aeroxbud on Jul 7, 2019 19:10:03 GMT -5
On yes the wheels make a big difference 👍
Post by Happypancake! on Jul 7, 2019 20:17:22 GMT -5
I got real lucky in finding the rims. Almost impossible in US. Hardest part is finding the rear brake hub.
Post by Happypancake! on Jul 23, 2019 19:32:17 GMT -5
GETting there. Still a low end 4 stroking.
Post by harleyracer59 on Jul 26, 2019 20:18:11 GMT -5
do you have a replacement headlight trim ring? if you don't care about color I might have an extra for you, they look the same as express. is it?
Post by Happypancake! on Jul 26, 2019 21:05:53 GMT -5
do you have a replacement headlight trim ring? if you don't care about color I might have an extra for you, they look the same as express. is it? Same one. LMK if u have one. Whole assembly is the same also. Cheers!
Post by Happypancake! on Jul 28, 2019 15:40:03 GMT -5
Tuning
Post by harleyracer59 on Jul 28, 2019 16:07:42 GMT -5
what speedo app do you use? i like it
Post by Happypancake! on Jul 28, 2019 16:45:47 GMT -5
Post by Happypancake! on Aug 13, 2019 18:26:59 GMT -5
Need a bit more punch off the line. Had some dio springs laying around. 1000 rpm? 1500? Flip an coin
Post by Happypancake! on Aug 28, 2019 14:33:58 GMT -5
New variator to try
Post by Happypancake! on Aug 28, 2019 18:07:24 GMT -5
Variator stats Stock: 254g 89mm Camino: 214g 83mm Polini: 275g 95mm TJT: 388g 102mm Fixed side: 95mm
Post by Happypancake! on Aug 30, 2019 7:52:03 GMT -5
Looks pretty. I’ll try to take it for a run today
Post by Happypancake! on Sept 1, 2019 16:14:13 GMT -5
The polini smoothed the power band nicely. no mid and top end bursts. running 5gr rollers and stock contra spring. shifting is at ~6000rpm. may try a lighter roller/slide. hit 56mph.
Post by Happypancake! on Sept 1, 2019 16:22:45 GMT -5
