Post by Happypancake! on Oct 20, 2019 5:52:16 GMT -5
Those are originally on Honda Caminos. VHTF. I got lucky.
Post by Happypancake! on Oct 21, 2019 10:59:39 GMT -5
New pipe !
Post by Happypancake! on Oct 21, 2019 12:46:24 GMT -5
Seems to rip better but I’ll need to up jet as it hit 422f
Post by harleyracer59 on Oct 21, 2019 19:19:10 GMT -5
the whole bike is awesome. I love the kick starter you just acquired. I didn't know they made those. had to search it after I saw yours. very cool and tasteful build. I like every thing you've done with it. wouldnt change a thing
Post by Happypancake! on Oct 26, 2019 6:35:03 GMT -5
New pipe much better low and mid range. Top end same @ 58mph. Both some new reeds........they sent the wrong ones!!!!
Post by aeroxbud on Oct 26, 2019 20:17:26 GMT -5
You are crazy. I bet 58 mph is interesting.
Post by Happypancake! on Oct 26, 2019 20:39:52 GMT -5
Once it consistently holds 60 I’m done. Then tune for wheelie take offs!!!
Post by Happypancake! on Oct 26, 2019 20:53:58 GMT -5
New variator to try Update on the “polini” variator. It is not designed by polini to fit at hobbit. Motorkit, mods it to fit a hobbit. It is originally for a Peugeot speedfight 3 4T . Big thumbs up to Motorkit !!!!
Post by Happypancake! on Oct 29, 2019 22:10:02 GMT -5
My dumb mistake. Reeds ok. Need to put back together. New head showed up......
Post by Happypancake! on Nov 3, 2019 17:15:00 GMT -5
Post by Happypancake! on Nov 3, 2019 17:15:16 GMT -5
Transmission started kicking out and into pedal mode. Large cammed gear was sticking . Need to grind down a bit. Luckily i do have a spare. Since it's apart, i'll look at gear options.
Post by Happypancake! on Nov 3, 2019 19:26:30 GMT -5
A bit of blue die to find the high spots. Dremeled down. Moves smooth now.
Post by pitobread on Nov 3, 2019 19:42:22 GMT -5
get the pedal mode lockout ring from treats
Post by Happypancake! on Nov 3, 2019 20:27:25 GMT -5
get the pedal mode lockout ring from treats Then is no longer a MOPED....🤓
Post by pitobread on Nov 3, 2019 20:54:56 GMT -5
Pull the drive belt = moped
