Post by stancejontland on Feb 28, 2019 22:05:26 GMT -5
whats up guys. i just installed a flasher box for my high mount tail light on my car. and the led flashes the pattern but it stays lit while flashing. ill attach the videos of the light. but in the customer review videos the light "turns" off in between the flashes. if you guys know what could be happening let me know!! you can possibly see the difference in both videos. youtu.be/IJJrMbvsX-Uyoutu.be/OS19au4mnJA
Post by ryan_ott on Feb 28, 2019 22:35:55 GMT -5
Is this used in conjunction with the OEM filament lamps or does it replace it with a led? Led’s are quick acting where filament lamps fade away when turned off. Maybe they are to be used with led for the effect your looking for.
Post by stancejontland on Feb 28, 2019 23:56:34 GMT -5
Its just an in line box. But i did replace it with an led bulb. That goes in the cars socket. The bulb does flash. But it stays on and flashes. Its suppose to "turn off" during the flashing then stay steady after the flashing sequence is done. But mine is steady on while flashing at the same time
