Post by 2smokeruck on Mar 2, 2019 16:51:41 GMT -5
I have a 96 jog which has terrible suspension. I bought a triple tree from a japanese jog so i can upgrade the forks. Only place that ive found with forks that is webike but theyre all out of stock. Anyone know where to find forks with 25mm fork tube?
Post by aeroxbud on Mar 3, 2019 20:23:12 GMT -5
What is so bad about the forks? You can make quite a difference by changing the fork oil. Or even fitting spacers to the springs if they are too soft.
Post by Happypancake! on Mar 3, 2019 20:41:55 GMT -5
Ruckus stock shocks are -27mm. There are many aftermarket ones available .
Post by 2smokeruck on Mar 3, 2019 23:17:15 GMT -5
Theyre really bad. Either way the triple tree is bent, previous owner had an accident. I have a set of rrgs ruckus forks but they wont fit at all, i believe theyre bigger than 27mm. I want disc brakes anyway because im putting a 70cc kit and i have wheels for it.
