Post by bigluelok on Jan 5, 2010 17:19:54 GMT -5
i picked this baby up a couple weeks ago. it was posted here hondaspree.net/phpBB3/viewtopic.php?f=2&t=12560here are the pics i have so far. packed up in the back of my '92 integra hatchback unloaded back at home front view view from seat right side view left side view what do you guys think? is there anyway to bypass the ignition to see if it will start? before i go out and buy parts for to see if it will run and if everything works. Plans for it are. []get it running []ruckus variator stock or aftermarket []registered []strip it bare and clean it up rebuild it []63cc big bore kit []custom cyl. head work []ported and polished []bigger carb []Posh high output coil []convert to Pre-mix []rear shock []slam it []remove center stand and add side stand in the end i want it to look somethiong like this with lights and street legal. pic's belong to redrucker over on totalruckus.com
Post by 90GTVert on Jan 5, 2010 18:09:18 GMT -5
Welcome to the site. That's a damn nice scoot for free and I definitely like your plans/goals for it's future. Good work stuffing it in that 'tegra too. ;D
If you wanna bypass the ingition, you pretty much just have to see what it is switching on and off and connect them together. If you can get a wiring diagram for that model, it should be fairly simple.
Post by 90GTVert on Jan 5, 2010 18:18:40 GMT -5
Post by bigluelok on Jan 5, 2010 18:27:10 GMT -5
i have printed out the manual and have it at home. now for finding out what it connects to, is the hard part because when i remove the front panel i see a multi plug where 4 diffrent things plug into. and i can see where the wires go from there.
Post by 90GTVert on Jan 5, 2010 18:42:57 GMT -5
Looks like you should have green, black, black/white, and red. I think Black/White and Green will have continuity when the switch is OFF and no continuity when the switch is ON. So you'd wanna make sure they are not connected, which is probably just a matter of unplugging the ignition harness. Red and Black should have continuity when ON according to the diagram, so they'd need to be connected. You could probably just make a jumper with a paper clip or some spare wire that would work long enough to test. Make sure you've got a fuse installed when you try that. Sounds wrong to me, but that's what the diagram says (unless I'm reading it wrong).
Post by 2strokd on Jan 5, 2010 18:44:25 GMT -5
Welcome! Look forward to the build
Post by bigluelok on Jan 5, 2010 19:24:38 GMT -5
thanks 90gtvert i was thinking exactly what you said just didnt know how to accomplish it. will a car battery be to much poer to jump start the aero?
Post by Fox on Jan 5, 2010 19:46:48 GMT -5
You can jump it with a car battery. No need to start the car. It'll crank better if you put the pos+ on the scooter's battery and the neg- on the scooters frame. It won't hurt it.
Great find!
Post by bigluelok on Jan 5, 2010 19:50:31 GMT -5
thanks jmstar50 tomarrow i will post my bare bones 87 elite 50.
Post by 2strokd on Jan 6, 2010 14:55:57 GMT -5
Still wont start though, not if the ignition is in the off position anyway.?. If you dont have a key and plan on replacing the ignition why dont you just break it with a chisel or something to turn it on?
Post by bigluelok on Jan 6, 2010 15:28:26 GMT -5
because i dont know how lol. ive never broken an ignition before. do i just get a flat head screwdriver and a hammer and bang it in there?
Post by Fox on Jan 6, 2010 19:09:17 GMT -5
That's how I got home once when I lost my keys.
I hammered a screwdriver in there and twisted it and hammered and twisted etc until the guts of the lock failed and then it turned to the right and it started up.
Post by bigluelok on Jan 6, 2010 19:44:20 GMT -5
will try that when i get home after i make the g/f some tea for her cold.
Post by bigluelok on Jan 7, 2010 12:24:20 GMT -5
finally the roomate is back from mexico and now i can have the garage back since his car wont be taking up all the space.
Post by 2strokd on Jan 7, 2010 14:57:50 GMT -5
Sweet, now go pound a screwdriver in the ignition and twist that baby lol. I stilll love the fact the you stuffed it in the back of an Integra. Thats diehard....Reminds me a the time i wanted to go to certan spot and ride my Yamaha Blaster four-wheeler but i didnt have a way to get it there. My cusion owned a 92 Dodge Daytona and joking he said "we could just put it in my car...."lol, A half hour later we were cruisin down the road w/my quad hangin out the back of his car. Aaahh, the memories. Sorry to steer of course here
