Post by louiearnold on Apr 18, 2019 10:04:40 GMT -5
Post by louiearnold on Apr 18, 2019 10:08:34 GMT -5
Im still a newbie, so please bear with any obvious question that i may ask. Can somebody point me in the right direction? Sorry for the blurry pic.
Rune 75
Post by Rune 75 on Apr 18, 2019 10:18:07 GMT -5
How many miles on that belt ? To get it all the way out you will need a wider (new) belt or a shorter variator drive boss. 1mm shorter boss will lift/push your belt approximately 2.5mm further out. It's quite normal though that the belt doesn't travel all the way out.
Post by FrankenMech on Apr 18, 2019 15:01:26 GMT -5
Heavier weights may help also.
Post by louiearnold on Apr 19, 2019 16:56:26 GMT -5
How many miles on that belt ? To get it all the way out you will need a wider (new) belt or a shorter variator drive boss. 1mm shorter boss will lift/push your belt approximately 2.5mm further out. It's quite normal though that the belt doesn't travel all the way out. Thanks man! Solved my problem
Rune 75
Post by Rune 75 on Apr 19, 2019 17:08:32 GMT -5
How many miles on that belt ? To get it all the way out you will need a wider (new) belt or a shorter variator drive boss. 1mm shorter boss will lift/push your belt approximately 2.5mm further out. It's quite normal though that the belt doesn't travel all the way out. Thanks man! Solved my problem That's nice. What did you end up doing ? Just curious.
Post by louiearnold on Apr 21, 2019 11:17:08 GMT -5
Shortened my secondary sliding sheave by 1mm as per "cvt tuning guide" post.
