Post by wolfrx50kp on Apr 24, 2019 12:39:44 GMT -5
Hello everyone.
I am putting a big bore kit on my Wolf RX-50.
I currently have a stock cylinder with 69mm valves. I accidentally purchased a big bore head with 64mm valves (rookie mistake).
With my 47mm big bore kit (72cc) will the stock head perform up to par?
What is the main difference between a stock cylinder and a big bore cylinder of the same size?
Thanks,
Kyle
Post by islandscrub on Apr 24, 2019 12:43:30 GMT -5
Stock head = more compression, more power. Also more heat, but I've yet to see it really cause any problems on our builds.
Post by wolfrx50kp on Apr 24, 2019 12:45:03 GMT -5
Stock head = more compression, more power. Also more heat, but I've yet to see it really cause any problems on our builds. Ok I will install the stock head, thank you for your help!
Post by section1 on Apr 28, 2019 14:53:29 GMT -5
I've had good luck with the stock head.
