Post by dejavu165 on Jun 6, 2019 15:18:50 GMT -5
Just got a scooter and started to get it running again. It fires right up but runs super rough, revs kind of go up and down holding the throttle open. I posted a video to make it a bit clearer. I figure it was fuel related, it has a new carburetor. Runs the same as the old. I though it must be a timing issue, but the timing, and stator look perfect. Has good spark. My only other thoughts are maybe something wrong with the valves?? The gaps are good. Any ideas? youtu.be/9bEgTdZHdFw
Post by sdsbassist on Jun 16, 2019 17:46:30 GMT -5
Same issue! Any luck?
Post by pinkscoot on Jun 16, 2019 19:27:34 GMT -5
When you hook the air box back up it will probably run much better.
