Post by jloi on Jun 12, 2019 11:50:12 GMT -5
GY6 150 cc - This new motor has rattled ever since I first installed it and drove it . could use some input from experienced people please . is this a common occurrence with new motors ? This is definitely something I should take a look at right ? and inspect variator , rollers etc. ? right ? It is definitely a roller type rattle . Could this be the cause of carb/scooter running rich. I have about 200-250 miles on this motor . Have put in 3rd spark plug now, each one has been black.
Everything is stock on this scooter . Upgraded to Keihin carb . Just ordered today sliders for this variator . 12g. I called where I ordered /bought this motor from , he couldn't tell me what weight rollers it comes with .
The old motor never rattled before or after I replaced the rollers/variator when the belt broke .
I've seen different vids including Brents' and Ill be watching more to make sure I get all this on right .
any input is greatly appreciated since I have limited exp - Thank you
Post by 90GTVert on Jun 22, 2019 14:46:09 GMT -5
I would guess it's separate from the rich issue. If plugs are black, it should be attended to with some carb tuning or finding out what else is up like a clogged air filter etc... Then see if anything changes. Rattles are not uncommon. I would think it was strange if most of my scooters didn't make some sort or rattle. Could be nothing. Could be a warning sign. Sometimes there's not much you can do other than listen the best you can to pinpoint it and pay attention to exactly what makes it rattle or when it happens and then to inspect areas of the most suspicion.
Post by jloi on Jun 22, 2019 15:14:56 GMT -5
Dexameth/Tyler has helped guide me a lot on the phone at PFS . Per your vid on rollers/sliders I just installed 12g sliders and I think i'll soon change /upgrade both variator and clutch assembly and maybe belt. I was telling Tyler as far as speed goes I'm only interested in increasing off the line/ bottomend speed. It goes fast enuff for at 55 . Hardly ever do that even . Scary for me . Not a long time rider like you guys . Too old . Told him my whole goal is to convert to Naked so as to make it more attractive/ saleable. I'm a perfectionist to the nth degree so I know I can do a good job. I just don't have tech. knowledge. but I'm getting there nevertheless . I also went from a 102 main jet yesterday to a 100 . Din't have the desired effect . Also went up and down with the needle sur clip. So still tuning . Do I need to worry about dumping too much fuel into engine from too rich and ruining engine over an extended period of time ? Thanks soo much for your reply . I remember your a 2t and I guess not especially 150 . so thank you . it helps I'm not really conversant with the differences between 2t ,4t etc. . I'm really amazed at the encyclopedic knowledge I see here from the various guys , Especially - OLD GEEK . but many others too . and your vids with your attention to details thru the years
edit: forgot to mention - adjusted valves yesterday too. set both at .004. sliders reduced rattle/clatter and also valve adjust helped.
I asked in a post , don't remember where , if I got the timing chain 1 tooth off could that affect AT ALL the carb/ running rich? or otherwise not timed accurately , maybe just off the mark a little . an example of I just don't know . I google things sometimes searching unsuccessfully .
