bluebob71
Post by bluebob71 on Jul 9, 2019 21:57:44 GMT -5
wondering if a 26mm carb is fine for a stock 157qmj motor looking to make a order from partsforscooters
Post by pinkscoot on Jul 10, 2019 9:29:00 GMT -5
My Italian 150's all run with a 26mm carb if IRC my Znen 150 came stock with one. If no mods that would be fine.
Post by lilpinny on Jul 10, 2019 10:15:41 GMT -5
I run a 28mm oko pwk. Mine is a 170, but I ran it when it was a 150 too. 26 should be fine.
06gix
Post by 06gix on Jul 10, 2019 11:33:43 GMT -5
I got a 26mm cv carb from partsforscooters with some jets. Instantly put a 130 main jet and strapped it to a brand new 150cc with no tuning other than idle I have already stuck 200 miles on it with it running very well. I do have a open exhaust and a foam filter.
Post by dexameth on Jul 10, 2019 13:20:00 GMT -5
I got a 26mm cv carb from partsforscooters with some jets. Instantly put a 130 main jet and strapped it to a brand new 150cc with no tuning other than idle I have already stuck 200 miles on it with it running very well. I do have a open exhaust and a foam filter. Are you under sea level?? I ask because with the same setup, 26mm & UNI filter with open exhaust I was at 115 main. 130 would be flooding it and if it runs it would actually be robbing you of power. Might even be prone to cylinder washing...
bluebob71
Post by bluebob71 on Jul 10, 2019 15:07:34 GMT -5
I got a 26mm cv carb from partsforscooters with some jets. Instantly put a 130 main jet and strapped it to a brand new 150cc with no tuning other than idle I have already stuck 200 miles on it with it running very well. I do have a open exhaust and a foam filter. haha thats a big main jet im in michigan so i dont think that would work. thanks for all the replies tho. gonna order the carb they have.
06gix
Post by 06gix on Jul 10, 2019 16:59:52 GMT -5
I got a 26mm cv carb from partsforscooters with some jets. Instantly put a 130 main jet and strapped it to a brand new 150cc with no tuning other than idle I have already stuck 200 miles on it with it running very well. I do have a open exhaust and a foam filter. Are you under sea level?? I ask because with the same setup, 26mm & UNI filter with open exhaust I was at 115 main. 130 would be flooding it and if it runs it would actually be robbing you of power. Might even be prone to cylinder washing... I double checked the packages and sorry for bad info it's a 125 main and in 200 miles I Havnt pulled the plug to check it. I'm in va and this new motor is getting broke in wot. Dex. You hooked me up with the parts. I do know this 150 runs way way stronger than the 50cc and I know I need some tuning and I do have the stock main that came with the carb I got from partsforscooters also have a 120 and a 130 main in stock but I put in the 125 before I even started it go first time and it runs very very well so if I can tune it better then Damn it will be fun ......
Post by dexameth on Jul 11, 2019 8:01:18 GMT -5
Well hey if it works, run it! Just sometimes when that big of a jet is working, it's cause of a small air leak somewhere and you are just creating a better mixture with the larger jet. Might wanna double check everything just to be sure.
06gix
Post by 06gix on Jul 11, 2019 14:18:53 GMT -5
Not trying to rob this post just wanna say 26mm cv carb from parts for scooters works awesome as how fast I got the stuff I ordered I highly recommend both decisions .
