Post by captjeff01 on Jul 15, 2019 7:48:09 GMT -5
2019 taotao lancer 150, blowing fuse at the battery, any ideas
Post by jackrides on Jul 15, 2019 13:40:12 GMT -5
Start with a wiring diagram and a lot of fuses. If you don't have one for your scoot, look at the left side of this page "Directory", "W", "Wiring Diagrams", "Tao Tao Thunder" is probably close. If you don't have an alarm, all those wires can just hang. You can see that from the fuse, the 'hot' wire goes to the regulator (which feeds power from the stator (alternator), then thru the keyswitch to the lights (except headlights), and the starter circuits. Congratulate yourself, you just became an electrical technician! Plastic parts have to come off to access the connectors. A Real PIA! Disconnect one circuit at a time till fuses no longer blow. It does take patience.
Post by captjeff01 on Jul 17, 2019 14:43:02 GMT -5
Thanks I found it !!
