Post by captjeff01 on Jul 17, 2019 20:34:29 GMT -5
Recently adjusted the valves on my 2019 taotao lancer 150 as per YouTube videos, set them at .005 now the bike seems to have lost 5 mph down to 50 from 55, coincidence ? What are the symptoms of valves being too tight, maybe ?
lupo76
Post by lupo76 on Jul 18, 2019 1:11:51 GMT -5
.005 what?
Inch? mm? Potatoes?
Post by captjeff01 on Jul 18, 2019 7:01:05 GMT -5
So if they are too tight, how would it affect performance ?
Post by jeff84 on Jul 18, 2019 12:00:00 GMT -5
usually too tight will cause hard cold starting, unable to start when warm, stalling at stop signs.
Post by captjeff01 on Jul 18, 2019 12:03:22 GMT -5
Thanks, that eliminates that, it has lost to end speed and it surges some, at a loss as to why ?
Post by SMALL CC TEK on Jul 18, 2019 16:11:28 GMT -5
Is that all you did adjust valves and lost mph? Anything else any other adjustments oil change plug or anything ? Do you have a proper air pressure in tires 33 36 min .. Adjust them again COLD if you did not the first time make sure your on TDC see what happens .. Even if it's 90 degree in the room make sure your motor is near the same temp of the room be for adjusting them
Post by captjeff01 on Jul 18, 2019 16:16:50 GMT -5
Changed carbuerator, main jets etc , engine just seems weak near the top end even surges, kinda unpredictable, this my 3rd 150, never had this issue, and I did take off the vacuum lines as I have seen done on YouTube and installed petcock.
Post by jackrides on Jul 18, 2019 16:32:31 GMT -5
What is your main jet and air filter setup?
Post by SMALL CC TEK on Jul 18, 2019 21:47:34 GMT -5
Go back to stock carb and test it ! what jets are in the stock carb ?
Post by captjeff01 on Jul 19, 2019 9:30:38 GMT -5
New Japanese supposed carb with 120 ran about the same, went to 125 runs worse, filter is a pod type. Stock carb is a sealed one.
