buck1
Scoot Junior
Post by buck1 on Aug 4, 2019 9:46:23 GMT -5
Im having a issue with fuel filters not lasting more than a few miles on 2 different scooters , both 50cc.
I am using good clean gas and haven been able to see anything at all in the fuel filters. When I blow through the filters I can feel a light restriction .
These fuel filters are from Autozone and for a car. I am suspecting the filter paper may have too small of pores for the stock vacuum fuel pump to push through.
I am wondering if a Mikuni fuel pump would fix my issues? If so what part # pump ?
50cc engines 3/16 fuel line maddog 50 and a taotao future champion. Any advice would be great! Thanks in advance
Post by 190mech on Aug 4, 2019 9:57:08 GMT -5
Never use a paper type filter,only screen types should be used...
buck1
Scoot Junior
Post by buck1 on Aug 4, 2019 10:10:05 GMT -5
I had no idea! Great help Thank you!!
Post by FrankenMech on Aug 4, 2019 20:19:45 GMT -5
Try a Kohler #2505021s1 filter.
Post by jstich on Aug 5, 2019 2:43:27 GMT -5
I guess I've had good luck with stock paper filters for 13 k miles among two scoots.
Post by FrankenMech on Aug 5, 2019 9:44:57 GMT -5
I guess I've had good luck with stock paper filters for 13 k miles among two scoots. You must have
Many people haven't, so why should anyone rely on 'luck' when good alternatives are available that don't require luck. The Kohler #2505021s1 filter has a fine plastic mesh that is even reusable. They can be had for about $5-6 each.
I have also found them at farm supply stores, Northern Tool, auto parts stores, and small engine shops.
The Kohler #2505021s1 filter has 3/16 & 1/4" inlets. The Kohler #2505022s1 filter has 1/4 & 5/16" inlets
Post by geoffh on Aug 5, 2019 15:35:25 GMT -5
Not sure which scoot you have but my Yamaha CS50 (Europe only) has the filter hidden away in the petcock and I only found it 3 years after I bought the scoot
Post by milly on Aug 5, 2019 15:46:50 GMT -5
I picked up the two on FrankenMech advice that he listed and they be great and have swapped them between scooters. Bit more in cost than auto stores but damn sight more cost effective.
Post by geoffh on Aug 5, 2019 15:51:01 GMT -5
I,m not racist but 'they be great' was long John silvers last words
Post by milly on Aug 5, 2019 17:09:19 GMT -5
I,m not racist but 'they be great' was long John silvers last words Geoff Well that be because I be from 'ampshire where we speak proper loike geoffh 😊
buck1
Scoot Junior
Post by buck1 on Aug 7, 2019 6:59:50 GMT -5
Great advice! Thanks everyone!!
phatmanxxl
Post by phatmanxxl on Aug 8, 2019 17:58:46 GMT -5
I use lawn mower filters from Walmart or AutoZone in a pinch, order a pack of 10 scooter filters in the mean time.
Post by FrankenMech on Aug 9, 2019 17:05:02 GMT -5
I saw a plastic mesh filter in the small engine or lawnmower repair area of Oreally's. The inlet and outlet fittings were fairly small, but it had no markings. It was $7-something. I was picking up parts for my weedeater. New plug, primer bulb, air filter, etc. I now have to see if my weedeater runs after my repairs. It has been sitting for almost three years. The odds are not good...
Post by fugaziiv on Aug 20, 2019 10:04:15 GMT -5
Post by FrankenMech on Aug 20, 2019 15:27:37 GMT -5
Unless the metal element is stainless steel it will corrode from water in ethanol fuel. The corrosion will either block the filter or crumble the element. The wire mesh should be OK on the 3/16" filter and should be re-usable.
BTW, the weedeater was scrapped and a new one was obtained.
