Post by birdman on Mar 7, 2021 0:57:46 GMT -5
Post by yambw’s on Mar 7, 2021 2:25:13 GMT -5
That’s such a shame mate, makes me want to go check my gear cover 😳
Post by Zino on Mar 7, 2021 9:09:22 GMT -5
That squish is ok Alot of sport kits out of the box are 1.5 ish
That would not be your heat problem. your engine and crankcase is sealed right by your leak test .
Jetting or exhaust gasket leak would be where i would dial in on next
Post by birdman on Mar 9, 2021 4:42:36 GMT -5
Not perfect but as good as it gets without machining the head or risking the transfers not lining up at bdc
Post by Zino on Mar 9, 2021 7:09:21 GMT -5
That is a noticeable improvement down .2 mm . Run it as is and see how you like it .
I used glass plate and sand paper to bring mine down farther
Post by birdman on Mar 9, 2021 13:23:31 GMT -5
That is a noticeable improvement down .2 mm . Run it as is and see how you like it . I used glass plate and sand paper to bring mine down farther Did you address the combustion chamber or just the squish band. How did it affect your compression?
Post by Zino on Mar 9, 2021 19:52:48 GMT -5
I did not adjust the combustion chamber . I have run no head gasket just copper spray often enough with the athena kit . That gets squish to about 1.25 to 1.3 If I wanted more I would just sand paper off a .1 mm or so with figure 8's on sand paper and glass.
The last athena install I had the head decked about.3 mm by a machine shop and then just cleaned up with sand paper down to .9 so i could run the best base gasket set up that let me max out the ports . When I was a Kid we were real scientific in our approach We would just keep decking the heads on the snowmobiles until they blew up . And then promised ourselves we wouldnt go that far the next time . I make smaller changes these days .
Post by birdman on May 24, 2021 3:07:18 GMT -5
Post by yambw’s on May 24, 2021 6:05:53 GMT -5
Nice to see it all back together. Looks great! Where’s the key chain from 👀 The buzzetti branded side stands are really good Quality
