Post by Jwhood on Sept 30, 2019 13:59:13 GMT -5
for the monkey rims. if you decide to go that route. you can get a monkey disc brake front hub and from what ive found on the interweb only need to change to the monkey speedo drive, it should work out. what size axle are those forks for the rear, maybe you can talk pitobread into machining 2 of those slick rear hubs out of zx wheels. (I need one too) sounds like it will be a cool build. did you get the black "ct" manifold from treats? I grabbed 2 of them on their last sale. quality looks a lot nicer than the fleabay units. especially like the black exterior coating over the flakey chrome you get on the fleabay manifolds. Yeah I got it the ct Mani looks good I got that adapter but I don't wanna take them off the nice forks I have,I'd use my nice forks but the o.d is to big to fit in the triple tree I even tried to stretch the triple tree opening but then it messes with the bolt hole alignment so I'm gonna go with these forks and rpm wheels those monkey rims are to much headache plus pito is a no go on making a hub so I'll just go with the rpm wheels
Sum-azn-kid
Post by Sum-azn-kid on Oct 1, 2019 4:21:47 GMT -5
Those fork legs are for zuma/jog style bikes.
mattyslimz
Post by mattyslimz on Oct 1, 2019 20:07:15 GMT -5
Are you sure those aren’t the NCY tubes you have there? (An older style)
Post by Jwhood on Oct 1, 2019 22:20:17 GMT -5
Are you sure those aren’t the NCY tubes you have there? (An older style) I put paint stripper on there can't seen to get them to bare metal it was an old can of stripper don't know if it lost its stripping power I'm gonna work on them some more this weekend I'm gonna find away to get a brake caliper mounted to these legs I'm not throwing in the towel just yet
Post by Jwhood on Feb 24, 2020 5:39:12 GMT -5
Another piece too the puzzle in route this build has took a while to start but it's almost ready,stainless steel piarel drag (based off the yasuni c16) took a while to find one
Post by Jwhood on Apr 4, 2020 14:53:12 GMT -5
Does anyone have a stator side crankcase half for an af16 I need one bad
Post by Jwhood on Apr 4, 2020 20:37:58 GMT -5
Well started breaking it down today and found this how the hell does that even happen I never seen a case break that far back and I surely didn't do it
Post by 190mech on Apr 5, 2020 5:47:24 GMT -5
Ouch!Looks like someone TRIED to weld it back on..Do you have the broken part?If so it could likely be welded back together..Another case would be the best option though..
Post by pinkscoot on Apr 5, 2020 6:54:11 GMT -5
Well started breaking it down today and found this how the hell does that even happen I never seen a case break that far back and I surely didn't do it Wow, I never saw that when I had it. I also didn't get very far into it.
Post by Jwhood on Apr 5, 2020 10:08:58 GMT -5
Ouch!Looks like someone TRIED to weld it back on..Do you have the broken part?If so it could likely be welded back together..Another case would be the best option though.. No it was like that and im having a hard time finding that case half
Post by Jwhood on Apr 6, 2020 5:13:37 GMT -5
Post by Jwhood on Apr 6, 2020 11:13:17 GMT -5
Going to get a case half today from the Honda master near me,the 2t gods are looking over me in these crazy times we are going thru 🤪
Post by oldgeek on Apr 6, 2020 11:16:04 GMT -5
Back on track, glad you were able to source one!
Post by Kenho21 on Apr 6, 2020 12:06:31 GMT -5
Looks really great! I love that exhaust too.
Post by pinkscoot on Apr 7, 2020 9:50:30 GMT -5
I'm glad to hear it worked out, I was feeling guilty.
