Post by jbjhillbilly on Sept 3, 2019 23:22:58 GMT -5
Sweet bikes. Very fun indeed.
You had better hunting in Japan than I did. Osaka is barren unless you have a Ruckus or a Monkey/Ape.
Sum-azn-kid
Post by Sum-azn-kid on Sept 3, 2019 23:50:36 GMT -5
Yes. I recognize the bikes from hondaspree.net. Any rubbing with that fork so low? Nope. 90/65-10 pocket bike tire and Im only about 112 pounds lol.
Sum-azn-kid
Post by Sum-azn-kid on Sept 11, 2019 0:50:08 GMT -5
I bought a malossi full circle crank about 1 year ago. I finally decided to split my spare motor and install it, match the case to the corsa base gasket amd install a fresh corsa. Everything went well until I noticed the driveface splines didnt match up to the crank... there was alot of play between the driveface and crank splines. I checked the same drive face with couple old cranks all were tight. I started the motor up anyway and the belt was making a horrible sounds and smelled bad too. Ran around like that for a couple days and decided to pull out the new malossi crank... pretty pissed wasted $200-300 on a defective crank. Ordered a PG crank, new oem bearings and seals. Installing a new crank again.... checked the driveface splines on the crank before installing. It was nice and tight. Started the bike up, no strange sounds or smells. Just gotta break in an tune.
Post by Jwhood on Sept 11, 2019 6:00:41 GMT -5
I got the same issue happening on my Athena crank but it has about 2000 miles on it never had an issue like that just too lazy to pull engine,it's not a Honda though
Sum-azn-kid
Post by Sum-azn-kid on Sept 11, 2019 17:04:54 GMT -5
I got the same issue happening on my Athena crank but it has about 2000 miles on it never had an issue like that just too lazy to pull engine,it's not a Honda though First time Ive ever seen that. And on an Itialian crank too... but that malossi picked up speed way better then the stock crank and a little better then the PG. I may gamble $ on another one later.
Post by 190mech on Sept 11, 2019 17:26:13 GMT -5
Ya think they may have a matching drive face for their weird spline cuts?I find it hard to believe that CNC machined parts would pass QC if done wrong...
Sum-azn-kid
Post by Sum-azn-kid on Sept 11, 2019 17:32:18 GMT -5
Ya think they may have a matching drive face for their weird spline cuts?I find it hard to believe that CNC machined parts would pass QC if done wrong... Not sure, my other friend didnt have an issue with his drive face. But Ill look into it. Crank is already pulled out.
Post by pitobread on Sept 12, 2019 14:12:27 GMT -5
2 different Honda malossi cranks. You ordered the small spline one most likely.
Sum-azn-kid
Post by Sum-azn-kid on Sept 12, 2019 18:32:21 GMT -5
2 different Honda malossi cranks. You ordered the small spline one most likely. The big spline seals fit on the crank. And the crank was same size as the big spline I pulled out. Part number is couple post up. 53 7604
Sum-azn-kid
Post by Sum-azn-kid on Sept 12, 2019 23:17:47 GMT -5
2 different Honda malossi cranks. You ordered the small spline one most likely. Left is ruima, middle is af16 and right is malossi all big spline.
lupo76
Post by lupo76 on Sept 13, 2019 8:19:00 GMT -5
Mate, you still have that older pipe you had on it??
Sum-azn-kid
Post by Sum-azn-kid on Sept 13, 2019 12:59:30 GMT -5
Mate, you still have that older pipe you had on it?? Which one? Ive had 4 pipes on this bike.
Sum-azn-kid
Post by Sum-azn-kid on Dec 8, 2019 1:48:24 GMT -5
Sum-azn-kid
Post by Sum-azn-kid on Dec 8, 2019 1:59:52 GMT -5
Sum-azn-kid
Post by Sum-azn-kid on May 24, 2021 1:27:29 GMT -5
Got this bike back together, running an AF18e motor, Corsa cylinder kit still on OEM crank. Found a NOS JDM burial pipe for it too.
