Post by draven0914 on Sept 17, 2019 12:55:30 GMT -5
Hello ALL and thank you for all your help. and I am here in need of help again.......I was driving my scoot and got about 4 miles from home yesterday and went to make a right hand turn and the scoot just died.......I tried to re start it and it wouldn't start........its back at home and I tried re starting it this morning after checking the Belt thinking it let go and it wouldn't even turn over.......so I have the battery on charge right now.....
any ideas on what else it could be........
it has a full tank of gas the belt is good
thank you
Post by tortoise2 on Sept 17, 2019 13:09:37 GMT -5
139QMB with 80cc BBK? What fuel-spark-compression troubleshooting efforts have you made?
Post by draven0914 on Sept 17, 2019 13:14:11 GMT -5
to be completely honest I haven't done any.....I am really unknowledgeable when it comes to this kind of stuff
Post by tortoise2 on Sept 17, 2019 13:31:48 GMT -5
Yet another exercise in futility?
At least start by checking if the sparkplug boot is secure . . .
Post by dexameth on Sept 17, 2019 13:35:36 GMT -5
Does the engine turn over, and crank? Does absolutely nothing happen with the starter button? Do you only hear a click when the starter button is pressed?
This happened to me once, the dang spark plug cap had broken on the inside where it grips the threads of the spark plug. Cap came off when riding, left me "stranded". Sitting there, scratching my head and noticed the thing hanging down. I unscrewed the cap and just crammed the wire on the threads of the plug to get me home.
Post by draven0914 on Sept 17, 2019 15:05:38 GMT -5
So I charged the battery it wasn't that
It tries to turn over but "drags" like it doesn't want to..... I'll check the spark plug and let you all know in that next.. . Thank you for all the help
Post by draven0914 on Sept 17, 2019 15:53:27 GMT -5
Switch out the spell plug cap still the same
Post by dexameth on Sept 17, 2019 16:04:23 GMT -5
Check your engine ground. Sometimes they are on the valve cover, and when you rebuild the engine sometimes we forget to reconnect that - I have done it MANY times. Without it, your starting will be extremely weak and you may even lose spark. You could have had a good enough ground thru an engine mount to have it running and now it's just not good enough - or in the worse case the stator was handling all of the "ground" and burnt up.
Post by draven0914 on Sept 17, 2019 16:24:41 GMT -5
Would the Stator cause it to die while running???
I was driving it when it initially died.... And then wouldn't restart
Post by dexameth on Sept 18, 2019 7:20:27 GMT -5
Would the Stator cause it to die while running??? I was driving it when it initially died.... And then wouldn't restart It can... If and AC system your stator has 2 roles: charging the CDI via the "exciter coil" and then signalling the CDI when to release the charge via the pickup coil. Either one of those could have failed. On a DC system you'll only find the pickup coil. There's a how-to on checking resistances and voltages to see if your stator is good, I'll upload the link in a few.
Post by dexameth on Sept 18, 2019 7:21:09 GMT -5
Post by pinkscoot on Sept 18, 2019 9:01:10 GMT -5
Post by draven0914 on Sept 19, 2019 19:48:48 GMT -5
Have to coach football games today and tomorrow I'll be working on this over the weekend then you everyone.... I'll get back to you all on what I do and if it fixes it
Post by draven0914 on Sept 21, 2019 21:01:42 GMT -5
Check your engine ground. Sometimes they are on the valve cover, and when you rebuild the engine sometimes we forget to reconnect that - I have done it MANY times. Without it, your starting will be extremely weak and you may even lose spark. You could have had a good enough ground thru an engine mount to have it running and now it's just not good enough - or in the worse case the stator was handling all of the "ground" and burnt up. Can you or someone show me a picture of where the ground is it what it should look like.... I'm sorry but I'm very dumb to this kind of stuff and I'm going to tear this thing apart tomorrow and try to figure this all out Thank you
Post by dexameth on Sept 21, 2019 21:17:36 GMT -5
Check your engine ground. Sometimes they are on the valve cover, and when you rebuild the engine sometimes we forget to reconnect that - I have done it MANY times. Without it, your starting will be extremely weak and you may even lose spark. You could have had a good enough ground thru an engine mount to have it running and now it's just not good enough - or in the worse case the stator was handling all of the "ground" and burnt up. Can you or someone show me a picture of where the ground is it what it should look like.... I'm sorry but I'm very dumb to this kind of stuff and I'm going to tear this thing apart tomorrow and try to figure this all out Thank you Wire most of the time attached to the cam cover bolt or sometimes on a fan shroud bolt. Here's where mine is:
