jm
Scoot Junior
Post by jm on Sept 25, 2019 5:54:21 GMT -5
Hello. I was pulling some wires from connector with intention to derestrict it and now when I put everything back as it was scooter wont turn on. I need cdi wiring diagram or just picture how cables are positioned in connector to check if I did something wrong when I put that back together. Generic xor is 2013 model. Much appreciated.
Post by FrankenMech on Sept 27, 2019 1:20:14 GMT -5
Post by christopher on Sept 27, 2019 6:44:16 GMT -5
It might be easier if you post a few pictures of what you have, then someone who recognizes what you have might be able to help easier.
jm
Scoot Junior
Post by jm on Sept 27, 2019 8:40:20 GMT -5
This how my wiring looks. It supposed to be like this, but I’m not sure. Scooter won’t turn on. Wires are black, green white, black white and blue white. I need the same photo of correct wiring. Thanks. I will look at those manuals.
Post by christopher on Sept 27, 2019 8:48:43 GMT -5
I don't have that plug but can you even connect it wrong when you plug it in? Typically plugs have some type of orientation shape or tab to prevent plugging in incorrectly.
What do you mean by won't turn on? You can take the CDI completely off my bike and it will still turn on, just will not run. What doesn't work? Mine has a main fuse by the battery that connects to a lot if not everything when I turn the key on. Did you blow that fuse maybe?
Post by christopher on Sept 27, 2019 8:55:57 GMT -5
jm
Scoot Junior
Post by jm on Sept 27, 2019 16:52:31 GMT -5
I don't have that plug but can you even connect it wrong when you plug it in? Typically plugs have some type of orientation shape or tab to prevent plugging in incorrectly. What do you mean by won't turn on? You can take the CDI completely off my bike and it will still turn on, just will not run. What doesn't work? Mine has a main fuse by the battery that connects to a lot if not everything when I turn the key on. Did you blow that fuse maybe? Yes it has orientation shape. I draw the wires on paper before I pulled some wires out of connector. I put them in a connector the same as they were before and scooter won’t run. The power is on but it wont run. I will check that fuse. Thanks for info.
jm
Scoot Junior
Post by jm on Sept 28, 2019 4:33:41 GMT -5
It’s not a fuse.
jm
Scoot Junior
Post by jm on Sept 28, 2019 5:10:41 GMT -5
jm
Scoot Junior
Post by jm on Oct 1, 2019 5:11:39 GMT -5
I ordered new cdi and new 4 pin and 2 pin connectors. Is it possible that I made short circuit after changing different wires on cdi and now cdi is faulty? My father told me that when he check ignition, spark on spark plug was weak. That comes from CDI. Thats why I ordered new CDI. Any suggestions?
Post by christopher on Oct 1, 2019 6:31:30 GMT -5
You May have broken the CDI if you let wires touch, you also may have broken components at the other end of the wires if you didn’t take precautions.
jm
Scoot Junior
Post by jm on Oct 1, 2019 6:46:40 GMT -5
Case closed. It wasn’t CDI. Incorrect wireing. This is how wiring looks like for Generic XOR 50 year 2013: Sorry can’t upload image. 1-blue white 2-black white 3-black 4-white green imgur.com/3Qa5J0Z image
Post by christopher on Oct 1, 2019 6:50:58 GMT -5
You learned a few lessons, one is take pictures before you take things apart. I always do saved me a few times.
jm
Scoot Junior
Post by jm on Oct 1, 2019 6:58:02 GMT -5
For sure. Btw. I ordered unrestricted CDI. This will be fun.
