Post by jdl357 on Sept 26, 2019 19:26:53 GMT -5
Have 150cc water cooled scooter sometimes smokes for a second in start-up. Could this be the head gasket? Any suggestions?
Post by chehystpewpur on Sept 26, 2019 19:47:42 GMT -5
what color is the smoke? white is usually coolant but can sometimes be slightly rich and give a white or slightly grey/blue/black too. oil is generally blue smoke. typically valve seals or in the headgasket.
Post by jdl357 on Sept 26, 2019 22:46:51 GMT -5
How can I see if it's the head gasket for sure?
Post by chehystpewpur on Sept 27, 2019 10:47:00 GMT -5
the only way to ever know whats going on in a motor for sure is to open it up. but if its just super brief and not giving you a running issue or losing coolant or oil i wouldnt bother as it could just be nothing. you could even just have worn piston rings or carbon buildup as both of those can make a motor smoke too. though carbon buildup is usually seen smoking during wot.
