PDub
Ann Arbor MEEEEEchigan
Post by PDub on Oct 22, 2019 17:32:29 GMT -5
Honda Ruckus 49cc I use 5.5 gram Dr Pulley sliders. Runs well from 5-6 grams, 5.5 seemed to work best for what I wanted performance-wise. I weigh ~ 140 lbs
Post by meniscus on Oct 24, 2019 10:09:13 GMT -5
Thank you for the recommendation.
Post by SMALL CC TEK on Oct 24, 2019 10:19:00 GMT -5
Get a kit like this you will need it in the long run
lupo76
Post by lupo76 on Oct 25, 2019 3:46:16 GMT -5
Simply use 4,8g weights in it. Might help a little, I´m running the same setup in the same engine.
lupo76
Post by lupo76 on Oct 25, 2019 3:47:18 GMT -5
Get a kit like this you will need it in the long run And what scooter only uses 3 roller weights???
Post by christopher on Oct 25, 2019 5:14:23 GMT -5
You combine weights to get a set, you can get anything from 2.5 to 12.5 in 0.5 gram increments with that kit. For instance 6 and 7 gram weights average out to a 6.5 gram weight. If you want 7 grams use the 6 and 8 gram weights. When I was close and was trying sliders I bought 3.5 and 4.5 sets. I could get 3.5, 4.0 and 4.5 by mixing and matching. You put them in alternating as you go around.
lupo76
Post by lupo76 on Oct 28, 2019 3:57:45 GMT -5
I know, but it´s not meant that way. Weights must have the same weights. Otherwise they will wear off differently.
Post by christopher on Oct 28, 2019 5:29:03 GMT -5
I know, but it´s not meant that way. Weights must have the same weights. Otherwise they will wear off differently. I read these are meant to be used temporarily for tuning. After you find what weight you want you can get a good set of weights. That is how I used the set that I purchased. As for alternating weights for fine tuning long term I have read and watched several people doing it with good weights and using it long term. I have no idea what there results were.
Post by aeroxbud on Oct 28, 2019 9:42:23 GMT -5
I have mixed weights for years. I do try and keep them fairly close though. I personally don't like mixing weights with more than 1g difference. And normally less than that.
lupo76
Post by lupo76 on Oct 30, 2019 7:07:40 GMT -5
Before buying a set like that, why not buy a set with 6 weights? 139 QMB engines mostly use 5.5. Since you want lighter, buy from 5g down to 3.5 etc. Sometimes I just wonder...
