Post by 90GTVert on May 12, 2020 23:27:13 GMT -5
I’m thinking I’ll need 1mm or thereabouts, so I should be able to make them work. Worst comes to worse, I’ll sand them down a bit. I’m assuming they’re steel? Owl-Lou-Mini-Um
Post by tsimi on May 13, 2020 7:05:29 GMT -5
Maybe tsimi recalls the part number. 05-CW and 03-CW
Post by Kenho21 on May 13, 2020 7:09:19 GMT -5
I’m thinking I’ll need 1mm or thereabouts, so I should be able to make them work. Worst comes to worse, I’ll sand them down a bit. I’m assuming they’re steel? Owl-Lou-Mini-Um The folks in Maryland have a funny way of speakin.
Post by Kenho21 on May 13, 2020 7:09:47 GMT -5
Maybe tsimi recalls the part number. 05-CW and 03-CW Thank you!
Post by Kenho21 on May 13, 2020 7:18:57 GMT -5
Pretty pricey for some thin pieces of metal. I think I'll wait to see how those spacers Brent is sending me will work out first. I may order them afterward just to have on-hand though.
Post by aeroxbud on May 13, 2020 7:41:55 GMT -5
The folks in Maryland have a funny way of speakin. At least they pronounce the second "I" in aluminium. As it should be, Speaking the queens English.
Post by Kenho21 on May 22, 2020 10:14:38 GMT -5
Finally had some time to mess with the Zuma yesterday and the kickstart lever arrived, so I could start it haha.
I'm getting pretty close to having the carb dialed in I think. Still getting a somewhat inconsistent idle, but I'll wait until it's a little more dialed in to worry. The idle has gotten better the closer I get to a good tune otherwise.
My cruising temps are between 180F-200F though. Guessing that still sounds a bit low? I think I'll try swapping from the BR9ES to a BR8ES and see if that helps.
What could be the cause of the low temps? When I tested compression (with my crappy and possibly unreliable compression tester kit), I only got about 130psi. If that's accurate, could that be why my temps are low? It does seem to run pretty strong and have plenty of power. It'll get up to 50mph with no problems.
CVT wise, still waiting on those shims from Brent (USPS has been incredibly unreliable and slow in my area). I did remove the plastic contra spring "seat ring" to try and alleviate any rear pulley binding/travel/opening issues and replaced the yellow with a white spring. It really woke it up and fixed the crazy high revs and slow speeds I was seeing. Revs are around 8-10k on average now and speeds have increased dramatically, so it's somewhat rideable now.
Making progress!
For reference: 82MJ 36PJ 3/5
5.5gr White Medium 0% taut
Post by 90GTVert on May 22, 2020 10:28:46 GMT -5
Usually low temps are from being rich if performance seems pretty good. If you like the tune and gas mileage isn't horrible, you may be fine as-is. CVT wise, still waiting on those shims from Brent (USPS has been incredibly unreliable and slow in my area). I was just going to message you and ask about that. Hopefully they show up soon. Mailed 10 days ago, first class mail in an envelope.
Post by Kenho21 on May 22, 2020 10:30:06 GMT -5
You didn't happen to get a tracking number, did you?
Post by Kenho21 on May 22, 2020 10:31:13 GMT -5
10 days isn't outside the realm of normalcy relatively speaking... of all scooter mail coming right now, that's the most valuable lol.
Post by 90GTVert on May 22, 2020 10:36:11 GMT -5
You didn't happen to get a tracking number, did you? It was just sent in a envelope with a stamp, dropped off in a box. If it doesn't show up soon, lemme know and I'll see if I can cut more.
Post by Kenho21 on May 22, 2020 10:54:18 GMT -5
I'll let you know, but so far all of my mail has arrived, sometimes it just takes a couple MONTHS lmao. I think it'll show up soon. Thank you.
Post by Kenho21 on May 22, 2020 11:52:33 GMT -5
Oh yeah... can anyone tell me where in the hell this brake cable holder clips on?
Post by Kenho21 on May 23, 2020 7:14:54 GMT -5
90GTVert According to my USPS informed delivery email, your shims should be arriving today!
Post by Kenho21 on May 23, 2020 15:00:35 GMT -5
Excellent choice of stamp! Haha
