Post by benji on Dec 10, 2019 8:41:57 GMT -5
Also, with premix it may smoke a little more, since the pumps are usually throttle position variant I've noticed. Less on idle, more on wot.
lupo76
Post by lupo76 on Dec 10, 2019 9:25:09 GMT -5
Mostly any autolube system does much lower ratio than 50:1...
And 50:1 is not a low ratio at all with high quality synthetic oils of today. My Beta RR Factory MY16 needs 1% oil premix, if oil according to manufacturer is used.
I measured autolube output on a Honda Bali 50cc from 1996 a while ago, used a seperate Tank with exact 500ml of gasoline (premix) in it and had the oil hose ran into a seperate container. All that happened on some kind of dyno (only for simulating riding, no measuring) and we found out, that this Bali did almost 75:1 in average rpm ranges under load to simulate real riding conditions.
I do have another Bali with over 65.000km on speedo, autolube still works wonderfully.
Post by milly on Dec 17, 2019 13:49:57 GMT -5
Is this scooter one that is made in the old Vespa factory? Yes in India
Post by milly on Dec 17, 2019 13:58:19 GMT -5
Mostly all Peugeot 2T with autolube do the same... Why it´s a problem? First 2 minutes it´s more smoke than normal. Just ride it mate.... Problem due to manufactoring error for that year oil leaks past non return valve and I dont want it smoking everyone out. I now have a scoot that dont smoke, never had smokey autolube system's before on other 2T's if set up right. Not much experience with 2T Peugeot's other than you see a lot for sale as non runners due to imobiliser issue's'
Post by milly on Dec 17, 2019 13:59:55 GMT -5
Tiz all good and no smoke at wot like you would expect goes well too.
lupo76
Post by lupo76 on Dec 18, 2019 4:04:10 GMT -5
Mostly all Peugeot 2T with autolube do the same... Why it´s a problem? First 2 minutes it´s more smoke than normal. Just ride it mate.... Problem due to manufactoring error for that year oil leaks past non return valve and I dont want it smoking everyone out. I now have a scoot that dont smoke, never had smokey autolube system's before on other 2T's if set up right. Not much experience with 2T Peugeot's other than you see a lot for sale as non runners due to imobiliser issue's' Newer Peugeots are crap at all, I´m talking about the good old ones, like SV50 etc. All my two strokes, no matter if autolube or not, smoke in the beginning when still cold. This has nothing to do with autolube or premix, more that the unburnt but still hot gasoline fumes condensates in the still cold exhaust... Once it reaches its temperature, they dont smoke.
