mikeh
Post by mikeh on Nov 7, 2019 12:31:53 GMT -5
Thanks a lot guys! Yeah Dex I'm down in Bradenton! You guys are awesome, I got my 47mm valve head from you guys yesterday and only took one day. While on "lunch" here at the city Waterplant where I work as a jagleg mechanic I dremeled into the successfully got access to the original carb that came with the scoot. It's a brand new "gator" gy6 50cc, that really needs to get running before my wife kills me.
The stock carbs needle only has one adjustment, right in the middle, I might gut the crap Amazon carbs needle because it had many different levels. I'm going to get to it this weekend. I got a tach from Amazon yesterday along with my new spark, I made sure to put a little anti-seize on the threads this time 🤣
Dex if your cool ill DM you on here and I'll give you a call, maybe some over the phone help might be considering your local.
I'll keep you guys in the loop, I really appreciate the help!
-mike
Post by dexameth on Nov 7, 2019 15:37:47 GMT -5
Feel free to message me any questions - call when you're ready to order up parts.
joshk
Scoot Junior
BBK help.
Oct 5, 2020 8:40:24 GMT -5
via mobile
Post by joshk on Oct 5, 2020 8:40:24 GMT -5
I am installing a 47mm bbk on a new engine before putting the engine on my scooter. My issue is valve adjustments. The kit came with a new head, and after I installed the cam and rocker, I can't get the adjustment close enough for good clearance. I'm aiming for. 004 on both intake and exhaust, but I run out of threads for the locking nut at about. 007/.008. Just use the old head? Or longer adjustment screw, if they exist?
BBK help.
Jan 3, 2021 14:20:06 GMT -5
via mobile
Post by chaoticfury on Jan 3, 2021 14:20:06 GMT -5
Is it possible, that you've got 64 mm rockers, when it should be 69mm, or vice versa? The rocker arms must match the valves.
Post by GrumpyUnk on Jan 4, 2021 11:23:43 GMT -5
josh, might be a good idea to start a different thread... but I suspect you have incorrect rockers for your cylinder head. If you compare the tops of the valve springs/valve stem to the surface where the cover gasket sits, you should find that they stick up higher just a bit on one head and are a bit lower on the other. If that is the case, you have mismatched rockers/cam followers. They are specific for the different length valve stems. There is no performance benefit either way, unless you have a 'race' engine, between the two valve stem lengths, but you have to have matching rocker arms, or things won't fit nor work. tom
