Post by captjeff01 on Nov 16, 2019 19:58:08 GMT -5
Just purchased 2008 Chinese 150 good shape, low miles 2800, but after riding at high speed for a bit I noticed either engine oil or gear lube on top of cvt cover, can't seem to locate where it's coming from, any suggestions ??
Post by benhonda on Jan 29, 2020 22:48:25 GMT -5
maybe a bad seal where the cam chain tensioner is?
Post by jloi on Jan 29, 2020 23:15:04 GMT -5
check all your valve cover bolts and any head bolts that are accessible for tightness- slowly and carefully. don't want to just crank down on them and break one off. there is a metal tube on mine on front or top of valve cover - for port gases etc. . should have a hose going to rear for porting gases - could be leaking some oil there if it's old and nasty or if there's no hose . the oil could be moving back from there.
