Post by jetblack9090 on Sept 18, 2011 0:49:05 GMT -5
hello all this is my first post and i have a queston.i just bought a taotao 50 used and everything was running fine but all of a sudden over the last couple days after i start it up from cold for the first 10 or15 minutes when i come to a complete stop the engine dies and i have to restart it.but after that after it warms up a little bit its dosent do it.now i let it warm after i start it but still it does it and i was told by a mechanic that it might be the spark plug just changed it out still does it i check the fuel lines all looks good .some one said the valves need adjusting but i dont know if anyone has this problem or has had this problem please id like some help also when i get paid im buying a new battery just to see if thats it.could maybe also be the cdi module or maybe the relay or starter.thank you
Post by rocketdog on Sept 18, 2011 8:14:41 GMT -5
Jet, before you start spending money throwing parts at it, I would try adjusting the valves. That doesn't sound like the usual symptoms of valves that are too tight, but it's possible. It can make your engine do some strange things. It won't cost you anything but time if you have a wrench, feeler gauges, and a pair of small vise grips. Here's a video on how to proceed. 49ccscoot.proboards.com/index.cgi?board=4ttech&action=display&thread=713RD
Post by jetblack9090 on Sept 19, 2011 22:14:19 GMT -5
Well I did the valve adjustment that was the problem and I have to say that the scooter runs better now than when I bought it thanks rocketdog I really appreciate your help also i did a oil change too just to make sure it was running right
Post by rocketdog on Sept 21, 2011 18:08:13 GMT -5
Glad I could help out Jet.
RD
Post by skuldur on Sept 24, 2011 10:33:12 GMT -5
damn i have the same model, same exact problem, i will try this, hopefully it works, funny how when i have a problem i come here and usually someone is having it at the same time, damn cold weather lol
Post by skuldur on Sept 25, 2011 9:42:42 GMT -5
sweeet that worked, thanks for the tips guys
Post by ccam22 on Oct 10, 2011 14:23:22 GMT -5
I see you found and fixed the problem. But I had very similar symptoms to where it wouldn't idle and when I come to a stop the motor would die. I read somewhere that the wires for the auto choke in the battery box could get pintched and cause it to run poorly. So I checked and no pintched wires, but the positive(+) wires were slightly loose. So I tightened them and never had the problem since.
Just another thing to keep in mind and look out for.
Post by jordan50 on Dec 6, 2011 15:00:05 GMT -5
hello, just wanted to know if anyone can help me figure out what is going wrong with my taotao 50 scooter. It used to run great and always functioned well. I have had it for almost a year now and have managed to rack up 7000 plus miles. It started running really slow about two weeks back and then wouldn't start up in the morning. Once I got it started it ran like sh*t ever sense. I have been taking my other scooter to work and kinda just gave up on the tao50! I started it up today and it wouldn't even stay cranked and I couldn't keep it running. I don't know if this scooter is worth saving but I don't want to give up. plz help
Post by Deleted on Dec 6, 2011 16:18:35 GMT -5
hello, just wanted to know if anyone can help me figure out what is going wrong with my taotao 50 scooter. It used to run great and always functioned well. I have had it for almost a year now and have managed to rack up 7000 plus miles. It started running really slow about two weeks back and then wouldn't start up in the morning. Once I got it started it ran like sh*t ever sense. I have been taking my other scooter to work and kinda just gave up on the tao50! I started it up today and it wouldn't even stay cranked and I couldn't keep it running. I don't know if this scooter is worth saving but I don't want to give up. plz help tight valves and a sealed carb. i see it all the time.
Post by eagles86 on Mar 1, 2013 11:35:57 GMT -5
I have recently bought a taotao 50 n have yet to ride it. The engine starts fine but a soon as I give it gas it shuts off. Any ideas??
Post by 90GTVert on Mar 1, 2013 11:50:52 GMT -5
:welcome: to the forum.
You should make sure all hoses are connected and nothing is cracked causing a leak. I'm also wondering if the diaphragm in the carb was seated properly at the factory. You'll have to remove the top of the carb to see it. Pay close attention and you'll notice a rubber tab and a certain way that it mounts in the carb. If it's not seated properly or damaged it can cause the problem you describe.
jtoro
Scoot Newb
Post by jtoro on Mar 9, 2013 22:45:50 GMT -5
I think I have the same problem. 2012 50 CC Tao Tao will start and then die pretty quickly. Once it warms it will stay on but as soon as you take off the engine will slowly lose steam even with the throttle fully cranked, and the it dies. Fills like there isnt gas getting to engine. After 2-3 times of this it seems like it works itself our for a little bit and gets back to full speed for a mile or so but then the gas issue happens again and it dies. Could that be just a valve issue? I havent started looking at it yet. Not sure where to start. Any help appreciated
Post by 90GTVert on Mar 9, 2013 23:31:57 GMT -5
Look for any air leaks. Cracked intake, something loose, vacuum hose off, etc... Check the fuel system out. Lines, filter, and petcock. Check the float height. Clean the carb.
Post by toastiestaotao on May 27, 2013 23:54:08 GMT -5
What should the float height be on a stock ATM carb?
Post by 90GTVert on May 28, 2013 9:00:46 GMT -5
