Post by larry001964 on Mar 17, 2012 20:54:39 GMT -5
Before any body starts this project know it's VERY VERY EXPENSIVE !!!
Hey guys here's my stroker parts list, I have put this together
so that anybody trying this build can consolidate shipping cost
and save money... I will include only the parts I feel are absolutely
necessary.. Hopefully people can start building a kit around this and bring down the cost... At least that's my hope.
Parts For Scooters
Hoca Stroker Crankshaft
Hoca Hi Performance fan
Timing chain
Scrappydogscooters.
Oil Pump
Oil Pump Gear
New Intake studs
New exaust Studs
Free Flow Exaust
Final Drive Gears. 17/49
Enviromoto
NCY 85 cc BBK "52"mm
NCY HP Cam
NCY Big Bore Head
Engine Gasket Set
Oil Seal Kit
50 mm bbk Top end gasket kit.
Mainepeace
20mm carb
Hoca Tranny Kit Variator no larger than 87mm ( Use all but Contra Spring ) Stroker power curve is different..
Dr. Pulley sliders 1 set 7 grams 1 set 8 grams. ( depending on your weight you may have to mix these to get the best performance ). Will also need to cut vent holes in CVT cover..
Gates Premium drive belt.
Variator Fan
Tail Light LED ( made a big difference starting it )
Turn Signals LED ( made a big difference starting it )
Jetsrus
98, 100, 102, 105 main
Napa Machine Shop
Pressed old oil pump gear off crank and put new gear on
Pressed the old final drive gear off to put on the newer one
Smiths Farm supply and hardware,
bolts, Nuts, and washers..
Batterystuff.com
YTZ14S 12v AGM Maintenance Free Powersport and Motorcycle
Battery 230 cca 11.2 Amp.
Autozone
Oil
Degreaser
carb Cleaner
Spark Plug NGK
4 awg battery cables
Adventurous Scooters
Hotter Orange Coil.
motorcycle-superstore.com
Pirelli SL 26 Performance Front/Rear Tire's
Parts For Scooters
Timing chain
Scrappydogscooters.
Oil Pump
Oil Pump Gear
New Intake studs
New exaust Studs
Free Flow Exaust
Enviromoto
NCY HP Cam
NCY Big Bore Head
Engine Gasket Set
Oil Seal Kit
Mainepeace
20mm carb
Variator Fan
Jetsrus
Napa Machine Shop
Batterystuff.com
Autozone
Oil
Degreaser
carb Cleaner
Spark Plug NGK
Hotter Orange Coil.
