Post by darius823 on Jan 23, 2020 10:23:17 GMT -5
Its time to change my belt which better i have a 100cc gy6 with 10inch wheels
Post by viaqua on Jan 23, 2020 19:36:39 GMT -5
I have used the Glixal Racing belt and never had any problems.
Post by GrumpyUnk on Jan 24, 2020 11:00:05 GMT -5
Two brands stand out as far as I can tell: Bando and Gates. A standard 10" wheel will mostly have a 'short case' CVT, which will use a 669 18 30 sized belt. I think the short case has 8 bolts, 4 on top, 4 on the bottom. If you open the case, and inspect the current belt, you may find it has the size embossed or printed on the outer surface. You may have to wipe it off to see the printing. I have gotten belts from online dealers and aliexpress, with no rhyme or reason as to what shows up.
A worn belt will allow the engine rpms to rise without speed increasing much, i.e., slipping belt. The sides of the belt, the 'vee' part, will be shiny if it has slipped a lot. tom
Added:
If you want to purchase from DaRiver, I used this as the search: "139QMB belt"
