Post by magoconnor on Feb 7, 2020 18:37:51 GMT -5
Hello. So here is my problem, I got a triple tree which is made for 33mm fork legs, but I got a pair of 31mm fork legs that fits my new brake caliper.
Will it be possible to shim it down from 33mm to 31mm, or will this be unsafe?
If so, I need a 1mm round shim. A soda can is 0.25mm thick, so I will need 4 strips to make it work. Probably not the best way to go about it... Any good ideas what els I can use to make set of shims?
Post by 2stroked on Feb 7, 2020 18:54:52 GMT -5
Find a machine shop with scraps of tubing, or flat stock with the right thickness....
Post by 190mech on Feb 7, 2020 19:08:59 GMT -5
If you want to try it,I'd get a piece of 20 gauge mild steel(.036"),cut and roll it to size..That should work..
Post by ThomasTPFL on Feb 25, 2020 23:02:47 GMT -5
I was able to find 1mm shim stock on eBay when I was making the wrong bewrings fit a wheel.
