Post by ryan_ott on Mar 19, 2020 10:54:44 GMT -5
They also list the Mina clones so it’ll work on a Zuma. I stole this piston and used it on another Polini cylinder so it’ll work. When swapping pistons you need to watch the ring location pin but between cast cylinders they all seem to be the same area also crown height could be different. I’ve got 4-5 different cast cylinders and I’m sure they will all interchange. They just have different windows.
Post by ryan_ott on Mar 19, 2020 10:56:02 GMT -5
Really trying to think of a way to make the Corsa work with a 12mm pin, but doesn't seem like there's an option. Something is up with that cylinder I’ve used the same “Dio” piston with no issues.
Post by Kenho21 on Mar 20, 2020 19:23:35 GMT -5
I think I’m gonna keep this cylinder since I’m using the head from it. I also have a Dio I’ll be workin on after this, so the piston can be used for that, I’ll just use to source a Corsa cylinder somewhere or buy a kit and have an extra piston I suppose.
